Worn WD Lower Steering Shaft Support
wjohn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Worn WD Lower Steering Shaft Support
    Posted: 22 May 2021 at 9:14am
What are folks doing to deal with worn lower steering shaft supports? I am thinking there is not enough material here to re-center/bore out and put a bushing in, like you can do with the support and quadrant on the steering wheel shaft.
I was going to cut off the round portion and weld in a piece of pipe but after I got the pipe cleaned up there's more play than I'm okay with. The ID is a little big. I might try to get a chunk of DOM tubing that would have a tighter ID on that 1" shaft? Any other ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 6:35pm
One option may be to get a good used one? I am sure they are out there. Maybe someone is parting out a tractor? I dont think I have a extra but will try to look.
You might find a piece of pipe or tubing and cut the old one off and weld the new one on??
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 6:47pm
They have a grease zerk in them? I wondered what that hole in mine was for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 6:48pm
The pipe is probabaly 1-1/16 ID if it is a schedule 40 pipe.. You could cut about a 1/8- 3/16 inch slit in the pipe and PINCH it back together for a tighter fit.. Then weld into place.
Edited by steve(ill) - 22 May 2021 at 6:50pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 8:37pm
How about cutting out the worn section and weld in a section of pipe to match
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 9:13pm
Ha! Might as well have not been there on my tractor since nobody seems to have greased it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 9:23pm
I hadn't thought about cutting and pinching the pipe I have, then rewelding. I like that idea. I cut a piece to the right length and planned on welding it in place of the existing support. Then I cleaned up the weld seam inside and test fit it on the shaft, and that's when I discovered that it was still a little too loose for my liking.
I didn't want to cut the existing support yet in case someone has a better way of saving the part, and I didn't have the right ID pipe to weld in place yet... But pinching it down should work.
I have to imagine a lot of these never got greased and are pretty worn? Mine may be worse than most of them, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 9:24pm
I did get a package of new zerks and nuts with matching threads, so I can drill a hole and weld the nut in so the new part will still have a zerk.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 5:18am
I think that zerk got missed on a lot of geasings on many of these tractors. Finding a good used one may be tricky, most are worn pretty bad. At least the ones I've seen.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 6:19am
I have a bin full of those that are in better condition and also new shafts. Both wear into each other. Now that your package is on its way. The WC used a solid block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 9:58am
That's my fault for not even thinking to ask. Maybe I was wrong in assuming all the used ones are worn. I did weld my shaft up and worked it back to being reasonably round.
JTOOL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 11:09am
When installed does the zerk face down? If so, how did it wear like it did?
