200 surging |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8707 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Aug 2017 at 10:30pm |
Hi guys. I noticed mowing with disc bine the engine has a slight surge to it. And when you pull the rotary rake with it, I don't think my tech is accurate but anyway the tech showing around 1500 rpm every once in awhile it will like rev up a bit for a sec then back to norm. It seems to run ok with any other piece of equip. Whatever it is about those work loads it acts up. What do you think it is. Thanks
kinghunter ![]() Silver Level ![]() ![]() Joined: 30 Jan 2010 Location: Kansas/Missouri Points: 408 |
Im just guessing but my 190 did this and it was injector pump had started coming apart.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
My 190 does it BAD without pullin' anything!---- it is so bad the fanbelt squalls when it jerks! thanks; ac fleet
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
my 180 has done it for about 10 years. still runs o-k besides that
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5238 |
Sounds like a pump issue. Ed can fix the pump issue, I highly recommend him. My 190xt runs awesome since he worked his magic on it.
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2303 |
Just had my 185 that way, rebuilt pump solved it.
Ok thanks. Have it done this winter. I thought that just asking other opinions, thanks. I would use Ed but were far away from each other.have a place close by I could use
harry lodge ![]() Bronze Level ![]() Joined: 20 Dec 2011 Location: Des Arc, Arkans Points: 4 |
My 200 does this and every time it has been trash in the T where the fuel line screws in the tank. It already has a rebuilt pump on it.
Romans 8:28
200AC,8N,450 Farmall,350 Farmall, B Farmall |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5098 |
People send me pumps from one coast to the other lol! It does sound to me like the flex ring in the pump is indeed gone, and now the weight carrier is slopping back and forth in the slots. You can nurse it along, but when you have down time, it would be wise to get it serviced. As stated above, make sure the fuel supply is flowing good, and the return plumbing is open and free flowing as well.
I ll pm you my info and see what shipping would be. Thanks
