All Crop - Screen Problem.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Topic: All Crop - Screen Problem.
    Posted: 11 Jun 2011 at 7:25am
Have an All Crop 60. Had a wheat screen in it for several years. Wanted to try beans last year. Wheat screen easily came out and bean screen easily went in. Did fine job on the beans. Doing wheat this year and went to change out the screens --  the bean screen absolutely will not come out.  Yes, I feel a little stupid asking this, but is the some catch or locking devise on the back side ( side futherest inside)? That seems to be where it is stuck. Is there an easy access to that area from the other side - didn't see one.  Thanks.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 7:58am
Jim, take two small bolts out and the screen should pull out. Try moving it back and forth.
Maybe rusted into place. You can take the two chaffers above seive then you will be able to see the full seive.
Good luck.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 8:13pm
Sometimes grain or dirt will get wedged in between the screen and the slot and make them hard to pull out.  I find that they come out easier if I blow out between the slot and the screen with compressed air first. Several of the screens for my All Crop 40 have been cut down from larger screens, and they are really bad for that...
