KaBlamOO
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Topic: KaBlamOO
    Posted: 28 Apr 2011 at 10:54am
My riding mower blew up last week.  Now I have a new inspection window on the motor.
I don't really understand this failure, I changed the oil every two or three years,  only mowed my 45degree sideways hill twice per week,  only towed my AC B to the sandblast area on nice days, only hit a couple of rocks ....
Bob, North Carolina
1949 B
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:58am
There is a engine my barn like that, except the block doesn't have the hole in it!. I don't know what happened to this engine, someone said the OHV parts sometimes would fall off, and was a easy fix, fellow I got it from thought it had a more serious problem.
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 11:34am
That looks a lot like the 17 horse motor I just changed the oil in on my neighbors Craftsman 42" mower.  At least without the after picture. While reading your post I was going to ask if there were unusual signs before it happened but I guess you already answered the question. LOL
WhiskeySup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiskeySup Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 11:38am
Makes you wonder about those stories told about huge radial B-17 engines that had several cylinders shot off during missions and kept running long enough to make it back to base.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 3:21pm
look at the Honda engines, have a oil filter and low oil shut off .. that way you can forget to mantain it longer before it blows.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 6:54pm
musta been sum bad gas!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:20pm
Only changed the oil once every 2 or 3 years? I never let the oil in mine get dark. B&S last I knew recommends change oil every 25 hrs. When you figure how much oil it takes to fill one, it just doesn't make sense to let it get dirty...
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 11:57pm
A friend used to have a mower repair service.  At least once a year he would go on repair calls because "my mower just quit"  He'd check the oil, empty.  Ask, "when did you last check the oil?"  "Oh, you have to put oil in it?"
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 12:06am
Well least on my cast iron block Techumsa first time it siezed up when kid was mowing without checking oil I was able to etch the stuck rod material off the crank with caustic soda. crank was not hurt. Rod was rough so took a brake hone and smoothed it out then I miked it , took a little off the lower cap and ran hone again until I got oil clearance right. ran for two more seasons before it gave out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 3:46pm
Many years ago when I worked in a lawnmower shop, at least twice a year someone would bring a new big box store mower in that "Just quit". It was always obvious, no oil before it quit. Oil was then added after the fact. Nice clean oil and a blue crank pin = no warranty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 7:16pm
there's a hole in one of my rotary combines that looks kinda like that!! cept it's about 4 times that size!
zootownjeepguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zootownjeepguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 7:38pm
I once had a John Deere 317 that smoked (I prefer Non-Smoking tractors). I sold it to a neighbor As-Is and told him that it needed rings or more. He blew it up and asked if I would rebuild it and said he would pay for parts and my time. I agreed and he towed it over to my house. I opened the hood and saw part of the camshaft laying next to the engine. I took the cam back down to the neighbor and told him that I found the problem and handed him the cam. He said "Boy you sure took that apart fast". I replied "That's the problem, I didn't take it apart yet".
Luckily a friend had a good 17hp Kohler (out of a Deere 317) that needed a coil, we swapped the engine and used the old coil.
Rich Salvaggio
'31 Allis Chalmers U 7143
'46 Willys CJ2A Farm Jeep
'48 Caterpillar D2
Antique Garden tractors
*Other rusty old junk comes & goes without notice
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 7:40pm
the 16 hp kohler in my 716 did that once.  I had just bought it used from a dealer, and it suddenly started not running worth a hoot . I loaded it up an took it to dealer. next day he calls me up an told me he thought he had it fixed and took it out to run it around the building and it blew up... cracked like a shot.  it looked about like that.  I never did know what exactly happened
Dave H M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H M Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 7:54pm
Well give us the final countdown on what  the sights and sounds were before Kablammmo?
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 11:03pm
That engine must have been "made in China".  Obviously defective from factory!  ha ha
Why is there never time to do it right the first time, but always time to go back and fix it?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 7:34pm
   Ran when parked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 7:44pm
I've got an engine that is just the opposite. No matter what you do to it, it starts on the first pull. It's a Tecumseh on an OLD troy built tiller. My Dad bout it wore out about 20 years ago. I told him for ten years, it needed a valve job. After Dad passed, my brother loaned it out and got the valves cleaned up and re-gapped. Now when you bury it in the dirt and the governor kicks in, it blows oil out the valve cover so bad it makes the right tire wet with oil in about 20 feet. I might just have to pull the piston and put some rings back on it this winter.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 9:49pm
Did Tecumseh go under? I thought I heard that somewhere.
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 10:18pm
Unfortunately yes, Tecumseh is no longer.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 11:08pm
That looks like it will take 2 tubes of JB Weld.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 12:03am
I just picked up a used mower with a blown 25hp Kolher.No holes but both rods are sheared off against cyl wall after they burt/broke off the throw and it came back around.Drain plug hasn't been out and there was about a cup of oil inside.It too came from the"get on and go!" crowd.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 12:19am
this past summer I had some straw that was a little to wet to bail but we never got weather to get it dry so we raked it around for 3 weeks.  Big windrows out of the combine and we couldn't use the V rake so we used a couple old sidebar rakes and got to run the little Ford 4000 gas and the Allis D15 a little.
The neighbor and I were driveing the two little tractors down the road to go rake one afternoon, I had my radio headphones on and the little Ford is faster than the Allis on the road, the Ford started to slow down and labor, I leaned over to look down at the carb for some reason and about that time cast iron pieces, rod berring shells and a cloud of oil  and smoke came out the side and went past my head.
I never even backed off the throttle, figured it was over with anyway so I may as well try and make it to another neighbors yard.  We made it but the noise was terrable and a pretty intense shower of sparks comeing out the side hole as the crank was wipeing the rod.  The neighbor behind me on the Allis was laughing so hard he spilled his beer when he seen the parts fly out and me turn around and smile.
Another time with the WC pulling tractor I wound it up to take off and it stuttered, and died, no spectacular show, just a bulge in the block and a bunch of wate and oil came out the bottom.  Valve broke in the keeper grove and wiped out the rest of the engine.  I managed to save the flywheel and cylinder head.  I had good automotive valves, but for some reason the broken one was dark colored across about 75% of the break, may have had a flaw in it when the tips were hardened or something.  Blame it on bad luck.
