snowblower for Allis D-17 |
TonyF ![]() Bronze Level ![]() Joined: 17 Apr 2022 Location: Minnesota Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Apr 2022 at 2:45pm |
I have a 6 foot Loftness snowblower on my Allis D-17. I'm a hobby farmer without much experience in these things, so am always looking for advice. My uncle has had D-17s since the early '60s. He says my blower is too heavy for the tractor and could end up breaking one of the 3 pt arms. I have no idea about how much my blower weighs. It's an older blower, and looks pretty heavy duty. Is there a particular brand of blower I should use with my D-17? Last thing I need is to break a 3 pt arm. I see that Northern Tool sells a 6 foot NorTrac blower that weighs over 700 pounds. Is that too much weight for a blower on a D17?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54082 |
Not having seen either your blower, or your tractor, Its hard to diagnose from afar. Hows about more info? What series tractor, what brand blower or some pictures would go a long way toward answering your questions. Oh, and welcome to the forum!
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21866 |
If it is a series 4 D-17, the hitch ruggedness is the same as a 190XT, so I think your Uncle is wrong. You might need some front end weight ? You could have a HP issue but that is remedied by less than 6 ft cuts or holding the blower off the ground for a ways and then taking a second swipe.
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3801 |
We have had a 6ft Loftness blower on D17's since 1988 and have had no problems. Its been on 2 series 1's and currently is on a series3 so its a aftermarket / homemade 3 point not factory. It can get a little light in the front and you have too slip the hand clutch to regulate the speed but works good.
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
If the front end will stay on the ground, and hydraulics will lift it, you won't hurt the 3 point. MACK
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8616 |
I agree with the others. Nothing to worry about. I have a 6ft other brand(brand name I forgot but popular) on my 45 with modified aftermarket 3pt. little light on the front with 2 F&H rear wheel weights mounted on the front but no issues for many years.
