WD-45 carb issues
Andy NW Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy NW Iowa Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 carb issues
    Posted: 23 May 2011 at 11:09am
My WD-45 runs lean, even after warming up. I put a new carb kit in, I put in new Champion sparkplugs. I found out it didn't have a thermostat in it, so I put one in, helped a little. I found out someone had the plug wires switched around, helped quite a bit. After all this it runs pretty good, but if you put any load on it sputters before it takes off, and If I try to adust the bottom adjusting needle it does nothing. I can have it all the way in or out and I seems to run the same. If I put a little choke on it runs great. Also the tractor was stuck when I got it, although not very. Any Ideas?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 11:39am
Sounds like some of the "passages" inside of the carb are plugged.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 12:00pm
Yeah, I bet that the passages are plugged up with specks of rust. My 45 had exactly the same symptoms a month ago when I was plowing the garden. Cleaned it out and it was ok. Acted just like yours.   Unscrew the fuel line at the carb and make sure you have good fuel flow, too.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 1:36pm
Andy,  Dont know which carb you have.  Before you disassemble it again, take the bottom needle all the way out and look inside with a light to see it there is a jet you may have missed.
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 1:50pm
vacuum leak probably on the manifold. Sounds like you are sucking air. Check around the intake runners at the head.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 1:59pm
Sometimes when cleaning a carburetor the area behind the main jet which leads to the feeder tube in the throat gets missed. To clean that area you must remove the main jet and the feeder tube and spin with your fingers a small drill bit to scrape the crud out. A dental pick will work also. I don't have one but I think they make a small spiral brush thing that will fit in the hole.
Another problem that sometimes happens when people are repairing carburetors using more than one to make one is to use a non adjustable main jet with a adjustment needle instead of a plug. Any time the needle gets close to the jet it restricts it. The main jet could also be a size smaller than needed.  I have pictures of an MS carb where the non adjustable bottom was fitted with an adjustable top.  A person not knowing the difference can do the switch very easy. I found several Zenith non adjustable main jet carburetors for the Allis B's and C's that had the needle in where it should have had a plug also. Most of those run fine if the needed is not turned in.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 4:51pm
That tube on the main jet is VERY critical. you must remove it and clean ALL the tiny little holes. I use tip cleaners and tiny drill bits but fine piano wire or wire from a wire brush should also do the trick. Use lots of carb cleaner in the process.
These old carbs are pretty simple........but when rebuilding them...."cleanliness is next to Godliness"!
