80R mower belt tension |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
![]() ![]() ![]() ![]() ![]() Posted: 05 May 2012 at 8:13pm |
The spring was broken when I got it last month. I rigged the chain up [idler pulley]. I took on a trail run today & it works good, but while its running the belt is kind of jumpy. Should the belt be tight enough not to jump??? and where do i find a new one when this one breaks. thanks Keith So. Va.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I think the belts will get a kink in them just from setting and don't run real smooth...the idler spring is there for a reason. You might want to measure yours before it breaks....Agco might have them but they will be expensive (like over $100). They had their own special "twin rope" belts that probably were better, but for a price. I bought one with a close profile (industry standard) from a bearing supply house for around $20 that has worked well.
ALLIS EXPRESS!
This year: |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10761 |
The spring is for constant tension while mowing. The snubber chain is to keep it from bouncing. The manual says to release tension when not in use. Eldon is correct on the belts. Great mowers none the less. Dad's has cut a bazillion acres. Tracy Martin
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21854 |
Been around a few of them and it seems to be pretty normal to have the drive belt jumping at times........
1953CA ![]() Orange Level ![]() ![]() Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
What tractor are you running the 80r on?
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
thanks for the replies, it's rigged up on the WD-45. I say rigged because my 45 has a sort of permanant homemade 3pt. it doe's seem to work well & the price was right, it had been in the back of the boss's shedfor over 20 yr!!! He said I could have it, guess I'm a good employee!!!!! Keith
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9876 |
A good industrial supply house can get you a belt for around $30.
I just bought a Goodyear belt from Murdoc Electric in Wichia. The correct belt is a C-103.
ALLIS EXPRESS!
This year: |
