Maroon belly 7000 oil leak from inspection plate |
Post Reply | Page <12 |
RMA
Bronze Level Joined: 26 Nov 2024 Location: Canada Points: 24 |
Thank you!
I bought the service manuals and the parts manual (kit came with 4 different e-books?) |
Orange Level Access Joined: 12 Sep 2009 Points: 20723 |
Regardless. You must stop the external leak first. Then, move on to determining if and how bad a possible oil transfer problem really is.
RMA
Hey guys,
Not sure if I need to start a different thread? But my 3pth won't go down when I have the tractor in higher rims. It raises great, but lowering down requires lower rpm. This will be an issue once I fix the pto problem as the snowblower won't stay on the ground. I've already played around with the traction boost levers but it still does it. Thanks again! |
Pretty much sounds normal to me. If you've got 500 lbs hanging on it, I'll bet it works fine. Cold hyd oil causes what you are complaining about.
RMA
I've got an 8' dual auger Farmking snowblower on it that I can't keep on the ground. I realize it doesn't matter much without being able to use the snowblower until the pto issue is fixed, but figured if it was something internal then I could take care of it while it was split. Thanks again for your responses!
The two rear levers on the console must be clear rearward.
RMA
Thanks, I'll take a look and see where they're positioned.
