Will a Allis Chalmers model 17 loader fit a Wd??
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: Will a Allis Chalmers model 17 loader fit a Wd??
    Posted: 26 Nov 2017 at 7:45pm
Picked up an allis Chalmers model 17 loader recently. Guy I bought it from says it was on a wd. I was under the assumption that the model 17 only fit the D17???
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:58pm
If it has the WD mounts it will fit. My WD45 had one on it when I bought it. I am sure someone will correct me if I am wrong!
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 5:46am
A Model 17 loader mounts to the rear axle L & R housings with special brackets that attach to the axle housing bolts.
A Model 9 for a WD usually clamped to the L & R side frames.
Like Rusty said, if it has the D-17 rear brackets, it may work.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 7:22am
Thanks for the replies everyone. Anyone have a model 17 on a Wd or Wd45 that could shoot a few pics of how it's mounted? This loader is missing the rear mounts so ill probably have to fabricate them.
Thanks!
Ben
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 2:50pm
If you sign up with 'Grandpastractors.com'
there is a great link to all the early Allis Loaders
Allis Parts Catalog No. D47 Farm Loaders May 1965
D-17 rear brackets on page 78
Gary
http://grandpastractor.com/kunena/allis-chalmers-tractors.html
http://grandpastractor.com/kunena/allis-chalmers-equipment/685-allis-chalmers-farm-loaders-may-1965.html
Edited by Gary - 27 Nov 2017 at 2:52pm
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 6:35pm
I had a #17 on my '45 for a while.  All the mounting holes for the loader bracket did not match up with existing holes on the '45 frame.  The axle mounting worked ok.  Note, the '17 is high pressure low volume, so if you put it on a '17 IV it will not lift more than about 1,000# - voice of experience.  But, still works for most stuff and I do like it on my '17 IV.
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 10:08pm
Gary
Thanks! There's lots of good info there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 10:12pm
I'm guessing you just drilled your own mounting holes? Also, is the rear mount the same for the Wd45 and the D17? I couldn't find any different mounts in the parts book in the link at grandpa's tractors, but thought I'd ask.
Thanks!
Ben
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 5:20am
Baverwolf
As I mentioned above: "A Model 9 for a WD usually clamped to the L & R side frames"
If you look in the index at the front, the Model 9 loader ( which is for WD and WD-45) is on page 65.
The rear of the loader frame clamps to the tractor 'side frame' with 4 'J bolts, each side, as shown in the picture.
Gary
