D-15 trans fluid
bbfalk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbfalk Quote  Post ReplyReply Direct Link To This Post Topic: D-15 trans fluid
    Posted: 30 Oct 2020 at 11:41pm
Trans fluid is foamed.  How do i drain it ?   What is replacement fluid ?
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2020 at 5:48am
Dunno why your trans oil is foamy . Thinking there's a 1+1/8" drain plug on the bottom . I use universal trans/hydraulic oil (821) . HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2020 at 7:38pm
Water in the tranny, like from a leaky shifter boot can make it foam, so can wrong oil or a leaky suction line.  A simple test, is to catch some oil, from the first drained oil, from above mentioned plug, and heat it up on a hot plate.  If you see steam bubbles coming out of the oil, its water.  If not, look elsewhere.
