Help choosing implements for 5040
Acooper1983 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acooper1983 Quote  Post ReplyReply Direct Link To This Post Topic: Help choosing implements for 5040
    Posted: 30 Oct 2020 at 8:21pm
picked up a 5040 that ive been getting up to snuff.   Wondering what size implements i should look to get for it.  How many bottom plow, how big of 3pt disk, spring tooth harrow, etc.   probably prefer 3pt implements as opposed to drawbar style as im just using it for foodplots and have some tighter trails and hills to go over.  I have loaded tires, as well as a FEL.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 8:44pm
I'd go with a 2 bottom plow,6 ft disk, a subsoiler to tear out the tree roots in the food plots.I also use an old JD 3pt ripper from the 1950's it tears up the ground and makes working up a seed bed easier and quicker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acooper1983 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 8:59pm
only a 6ft disk? i figured it'd pull at least something that is even with the outside tires.  ive been looking at the 78" king cutter 3pt disk.   I pulled a 48" pullbehind with a atv.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 9:16pm
 5040 will handle the wider disc but figured you wanted to keep it narrow as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acooper1983 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 10:03pm
ok, i gotcha.  I more am concerend with it just being a 3point.  Trails are wide enough, i just want to make sure i can cover the tire tracks, how big of a disk would the 5040 handle on the 3 pt? 8' max?
