L3 combine pickup problem (pics)
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: L3 combine pickup problem (pics)
    Posted: 08 Oct 2023 at 9:15pm
After combining 1 hopper and a bit on the second, the pickup slows down to a stop.
Touched the drive motor and the reservoir and they are both hot!
What could be the problem/solution?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 8:35am
My first thought is the variable speed has slowed it to a stop, is it hooked up and working?
They seem to run hot under normal conditions on mine
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 9:58am
Variable speed control is working and the oil level is good. I had just changed the pickup belts prior to starting and checked the pickup bearings which are good.
I'm going to change the drive motor this morning.
Of course its always the holiday weekend when these things happen...Maybe tomorrow a new filter too.
