Gas getting into air cleaner bowl?
MJR1984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJR1984 Quote  Post ReplyReply Direct Link To This Post Topic: Gas getting into air cleaner bowl?
    Posted: 19 Feb 2017 at 10:04am
Hey I've got a 47 c model with a Marvel Schelber carb and I'm getting fuel in the air cleaner bowl. It also leaks fuel between the carb and the air cleaner. Is it a float issue in the carb.? And would a simple clean out or adjust of the carb fix the issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 10:09am
odds are REAL good  the needle valve is NOT closing off, so the carb 'floods'. My D-14 does it....my other D-14 does it...my other ,other D-14 doesn't !
You're best to pull carb off, clean real good, do it again 2-3 times. Also remove gas line, spray brake cleaner(carb cleaner) in it to remove any varnish buildup. It's that crud that can gum up the needle valve/seat area of the carb. Fresh gas from a sweaky celan tank 'melts' the varnish on the inside of the gas line and it gets into the carb...
Jay
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 10:40am
Shutting off the gas when the engine is not running is your best bet if and when you can get around to fixing the issue.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJR1984 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:30pm
Ok awesome I took the carb off gonna clean it tomorrow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:30pm
if I don't shut gas off on my WD,I'm pulling hose off and draining gas to get it started.
This page was generated in 0.075 seconds.
