GaryL's Model B Build Thread - Take a Peek |
Page <1 2345> |
GaryL ![]() Orange Level ![]() Joined: 18 Jan 2015 Location: Oklahoma Points: 704 |
Thanks again, Thad. BTW: Is the ended being boogered up going to be an issue? It looks like a pressed-in retainer that can't be removed now due to the housing being distorted. ![]() Edited by GaryL - 24 Jul 2016 at 7:32am |
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
If you need to get that out I think a good machinist could clean it up and pull it out they might need to clean the bore and sleeve it depending on how bad it is but it looks totally salvageable to me.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Stick a big screw driver or a pry bar in under that seal and pry it out. Then file any burrs out of the bore and make a slight chamfer on it. A die grinder with a light hand would be real handy for this.
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
Gary I looked through all the B parts I could find and didn't see any steering box parts. I found a good complete box for a C but It won't fit your B. I'm still looking for pics.
BenGiBoy ![]() Orange Level ![]() ![]() Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
I have an extra steering box, I don't know if it is good or not, it might not be, but it might still have the bearings or whatever else you might need. PM me if you are interested....
'39 Model B
Tractors are cheaper than girls, remember that! |
Does anyone have an exploded diagram of the Allis B steering box?
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
Gary, here is one I rebuilt some time ago. Hope it helps.
Also it is not recommended to use grease (I see the grease fitting). Remove the grease fitting and install a 1/4" pipe plug, use heavy gear oil. |
Gary, This diagram is for B&C disregard the parts on the lower left they are for a C.
Wdtractorman ![]() Orange Level ![]() Joined: 24 Sep 2013 Location: Kentucky Points: 975 |
Thank you for both posts. That's exactly the information I am looking for. As far as using oil or grease, I found a Jeep forum where someone details rebuilding a Ross steering box in a late-50s Jeep. He filled it with a mix of oil as was done in the era. A steering box discussion came up on an air-cooled VW forum I frequent, and one person who deals with various industrial chemicals stated John Deer Corn Head Grease is perfect for steering boxes. I'm planning to use the Corn Head grease and will do a write-up of my rebuild. Thanks again.
I think I got the bushing from MotionIndustrys.com you could get them from any bearing supply.
The Stud or Pin as it's sometimes called, I get from the John Deere dealer, it's for the Ross steering gear in the Model M, part number AM1515T. I have also gotten them from Tracy Martin. Bill B |
Sorry about the double post I was trying to do to many things at once lol, Explains why I couldn't think of pin too lol. As far as the corn head grease it works OK but I have trouble with it working out of the steering box between the tube and the box, I'm going back with oil as sone as I get it where it will hold some.
Cornhead grease won't make a mess if you have no leaks and DON"T pump the box full with pressure. If cornhead grease gets out, gear oil will easier.
Corn head grease is better that regular gun grease, but what I'm geting at is I think that gear oil is much better expecially if your going threw the trouble of rebuilding it frist. Iv tryed it both ways and it seams to me that oil steers easier. I may have over filled mine with grease too, I wasn't sure how much to use so I put I think 10 or 12 pumps. It work fairly well for a few months before it started leaking, but I use my b to mow with weekly too so that my have something to do with it too |
Well I put regular grease gun grease in my CA when I put a bearing in the pedestal and with the Woods mower hanging underneath, I could steer it with one finger, Grease in the pedestal and the gear box. Dad put the grease zerk in the gearbox probably over 50 years ago and it has never been rebuilt, it just wouldn't hold gear lube anymore.
The adjusting screw Looks like it's been mashed quite a bit. It won't back out of the hole -- I had to screw it all the way in to remove it from the cover. I can't remember if that's normal or not. It was almost flush with the nut, so I'm wondering if I should replace it while I'm dismantling everything.
No need to replace it, just push the leading edge of the thread against a grinding wheel at a 45 degree angle, while you turn it a few times. Use a nut to check the threads before putting it back in.
If it was flush, it may be too short after you put a 45 on it, so you may have to get one from a good hardware store.
Bill B |
That's what I figured. Normally, the adjusting screw should be proud of the lock nut by at least ¼" - 5/16" assuming the steering box has been properly maintained during its lifetime. Based on the photos I have posted, it's obvious to see mine hasn't. Just another items on my list for my trip to ACE Hardware.
I've searched the forum for how to replace the mesh material in the air cleaner and am a bit confused.
1) Are there a few spot-welds to be drilled? 2) What kind of oil is used? 3) Is there anything that should be inside the mushroom cap? The one on my tractor is empty.
Mushroom caps normally have a corse screen to keep big bugs out. Typically the mess is held in by a metal thing that is spot welded to the container. But normally you can blow them out with air and soak them in diesel fuel and clean them without disassembly. If you have to take them apart the screens can be cleaned. As to oil just about anything will do I use 30 weight same stuff I use for motor oil just fill it to the fill line and check it once in a while if it looks bad water or dust dump it out and fill it up fresh.
Is there any way to replace the missing mesh in the cap? Also, a source & nomenclature for said material? I've not seen anything other than this --> http://www.steinertractor.com/ABC422-filter-element-oil-bath-air-cleaner
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Farmer fix. Put a piece of panty hose over the mushroom cap in dusty conditions. Tape it securely to the Air Cleaner Pipe. If keeping the
Dirt dauber wasps out becomes a problem leave the panty hose on all the time. |
Oh brother! Now I'll have to order pantyhose online so I don't get any odd looks ![]() Meanwhile, I sourced the oil seal for the steering box (SKF 9838 - Steering Gear Pitman Shaft Seal) from Rock Auto for $5.50 versus $10+ from many other sources. I also have a replacement steering pin. I was able to contact Midwest Steering as a source for parts. Unfortunately, the bearings and races cost $68/kit (2 kits needed) and some shims can be purchased used. I need to call Matt Scott to see if he happens to have parts (no response to e-mail). I was hoping to have all the parts I need by Labor Day.
Edited by GaryL - 28 Aug 2016 at 2:47pm |
It may be easier to get a new one a bit longer, but beveling the leading edge of the thread will NOT change the length of this one. |
You could weld any somewhat course screen to the bottom of the mushroom cap. As I recall it is typically a screen with holes about the size of your pinky.
I think that the holes in mine are smaller, but I would have to go look to make sure. I could get a picture if you want one.
'39 Model B
Page <1 2345> |
