G manifold |
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Topic: G manifoldPosted: 12 Jul 2022 at 9:48am |
By "cutting new threads", do you mean the old threads are stripped out ? If so, is there enough (cast) material to re-thread? Might try tapping it anew as Aaron said. OR, does it require going to the next size NPT? Then something else to consider.... If there's a machine shop in your area that has a CNC mill with a threading cycle. Ask them if they can do it. Shouldn't be too much of a challenge. Of course, both these suggestions assume there's material there. |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 12 Jul 2022 at 5:30am |
You can try to tap new threads in. When I had a shop do that with my D17 manifold, the tap split the top of the manifold. AaronSEIA
Kiwi
Joined: 23 Jan 2018 Location: New zealand Points: 391 |
Posted: 12 Jul 2022 at 2:54am |
Hi all is there anyway of cutting new threads for the muffler in a G manifold or do I need a new one.
Tractors Allis EB,two C,diesel G
