G crankshaft pulley from Steiner? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10757 |
![]() ![]() ![]() ![]() ![]() Posted: 07 May 2012 at 10:25pm |
Has anyone purchased a crankshaft pulley from Steiner's? I bought 2 and the bores are too tight by .002 , and keyways are not broached to correct depth. I called them and they will take them back, but have had no complaints. Just wondering if I got the only 2 that were incorrect. Thanks Tracy
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8613 |
I doubt it.Don't you love Chinese workmanship?
I can fix them, just didn't want to. Can't buy much that has quality any more. Tracy Martin
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
Tracy. Did you try them on a G crankshaft or just compare measurements to a original pulley?
Tried them on the crankshaft, then measured them. Tracy Martin
One thing about it Tracy.If you "finish" it it be have the correct spec/fit. Kinda a bugger workin around that interupted cut though.
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1852 |
Tracy: Seems like one should not have to machine a new part, unfortunately with the outmigration of corporate America oversee's we are left we having to be self reliant. I know that you are a wonderfully skilled craftsman and have no doubt that you can machine a broach and clean up the center hole to .002.
I have run into similar problems in the past and that is why I put in a metal lathe last year and will be adding a Bridgeport or similar very soon. Hard to find precision in today's society. Good luck....Orangeman
I got them finished. I wish I had the choice of low,middle and top quality when buying parts. There ain't no free rides. No way a man could of ever got that pulley over the key. But, they said they have had no complaints. Tracy Martin
