Opinions on tires |
AaronH
Orange Level Joined: 12 Sep 2009 Location: WI Points: 601 |
Posted: 13 Feb 2013 at 10:42am |
I would like to go with some 20.8-38s on my 210. It is just a farm tractor puller, but right now i have a pair of 18.4 armstrongs on it. Any suggestions??
Orange Level Access Joined: 12 Sep 2009 Points: 19596 |
Just mounting 20.8's on your existing 16 inch wide rims probably won't do you any good at all. If you choose to widen your rims, make them 20 inches instead of 18 inches wide.
kurtnwIL
Bronze Level Joined: 21 Dec 2012 Location: NWIL Points: 18 |
I tried our 7060 with 20.8s and at 15000lbs just couldnt get it to hook up. Have since went to 18.4r42s but it was drizling this year so i cant come to a good conclution. My brother tried his 220 with about the same results on 18.4r38s. Look back trough old posts to one about a class called to hot to farm. The ACs there are just awsome.
AaronH
so... I should look for a set of 20's, and mount them on 20 in wide rims and flatten out the tire footprint?
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7947 |
Thats the best, get all you can out of your tire
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4786 |
18" wide rims will be ok, but make sure you get a set of RADIAL tires. Around here, BFG powersavers are best, with 23* Firestones being a close second!
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 963 |
Same thing around here. BFG radials. 20.8
AS185
Silver Level Joined: 23 May 2012 Location: Waupaca Points: 91 |
1/2" to 5/8" lug no more you will pile up to much dirt. On a radial tire start at 10-12 p.s.i. when you pull away from the sled look at your tire ruts. You will see how much of the tread is making contact. 23 degree firestone radials work the best for me. They have more lugs than bf's do. The lugs are closer together which will help. If you can't "Sharpen or cut your tires. Put them on backwards, and spin them on concrete.
WildBill
Silver Level Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
I use a 7 inch variable grinder with a 24 grit disc. Make sure you see the rubber chunk off. If it starts burning it will plug the disc. Definitely firestones good luck !!
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
SuperM74
Bronze Level Joined: 27 Jan 2013 Location: Hustonville,Ky Points: 22 |
My boss and i used to pull a 1466 in the Hot Farm class in central Ky. 470 CI, 2.5 in 3 out smoke chopper, 13 Mil rotary, at 3000 RPM. The best tire we found for this area was GoodYear DT710 20.8 on 20 inch rims that were streched 2 inches. We tried bias field and roads, BFG Power Savers, and 23 radials. The DT710 worked best for us. We wasn't allowed cut tires either. Hope that helps you.
You can't make chicken salad, outta chicken sh*t! Proof's in the pudding!
jakeliu
Bronze Level Joined: 27 Feb 2013 Location: new york Points: 5 |
jakeliu
