185 allis chalmers
Message Reverse Sort Order
rickymotorbrains View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Topic: 185 allis chalmers
    Posted: 14 May 2024 at 10:43am
How much you want for it and could you send pic
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 9:49am
rickymotor, I have a oil pan off of a burgandy 7000 but I,m in ontario
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 1:19pm
where you live or can you give me some junkyard names to try
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 1:18pm
do you no where i could find one
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 6:53am
I,m seeing on AGCO parts that a late 185 Crank driven oil pump PAN is the same as a 7000 # 74024125, correct me if I,m wrong. Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 6:31pm
ok i dont mind the drain holes being different as long as it fits on the motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 12:57pm
can you send me pic of the oil pan
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 10:52am
Yes. I've actually got two of them,but as I said, they are both off of combine engines. They have the drain plugs in a different location than the tractor application. I also have one of the cam driven oil pump pans too. I can send you pictures if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 8:20am
did you ever get the pan out and look at it
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 10:01pm
cant find any that has the oil pan for the motor that has the crank driven oil pump all have the old style
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 10:51am
The pan that I have is a #4023964. It is off of a gleaner L or M combine. The only difference, from a tractor pan,that I see is that it doesn't have a drain plug in the bottom. It has drain plugs on each side. That would make it a little messy when draining oil in a tractor because of the front end wishbone.
Edited by Lynn Marshall - 02 May 2024 at 10:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 7:44am
Sorry for the delay in response. I've had a few other things come up recently. I'd take $20.00 for the pan. I need to get it out of storage to be sure it's correct. I think that there were only two pans for the 180-185, depending on the oil pump location. Mine might have been off of a combine engine, that had a crank driven oil pump, but I'm not sure if it's different than the tractor pan. Will check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 6:29am
I am a fortunate individual. If I drive no more than 2 hrs from my house, I can take advantage of SIX salvage yards for old tractor parts. I can't imagine places around the country that don't have anything ??????????
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:32pm
I recall a few years back I made a few trips up to Dry Ridge. I remember a farm out on Highway 36 near Jonesville. There must have been a couple dozen or more older AC tractors scattered all over the property. Various models from WD up into the 190 style.  You wouldn't be familiar with that place would you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 9:37pm
did you get my message
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 2:52pm
how much would you want for one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 1:26pm
I think that I have a couple of those, but the freight from iowa might be a killer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickymotorbrains Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 11:20am
does anyone no where i can find a oil pan for the 185 that the oil pump runs on crank the newer stile motor
