allis chalmers hd 16 dp buda 844 engine |
Post Reply | Page <123 |
russell
Bronze Level Joined: 08 Feb 2024 Location: australia Points: 37 |
Hi Codger
Have apart bearing spun on top of other have photos just not sure on the best way to post on here cheers
russell
Hi Codger
russell
Codger
a bit different one on top off other
russell
Codger
next journal as good as gold
russell
Std
bearings
russell
std
russell
Has any one got any thoughts looking at the crank shaft you would have to agree its pretty bad funny thing is not a lot of heat on rod ends or backings hmmm has any one been here before ? Is the metal on the crank just soft metal and if polished off crank may be ok? Its the Japan crank which i was surprised with i thought my model still had the usa crank geee i should give up but i keep thinking how good it was when using in the past any thoughts criticism welcome
cheers
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50653 |
Another way to check this is to take a long tapered punch, hold the punch in your hand and swing against an anvil striking the hammered surface, to the anvil. remember this sound. Ping! now strike against each individual bearing cap(if there's room!) the bad one(s) will make a Pock sound, instead of the ping sound...
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1817 |
Ok Russell; The engine may need to be removed for repairs. However to ensure the crankshaft will require regrinding it needs measured up before going much further. I would take an inch wide and 18' length piece of emery cloth strip and after rotating the crankpin, (journal) to the bottom of it's stroke and pushing the rod away for clearance, polish that journal with the abrasive pulling the emery cloth fully around the journal each way using your hands. Usually the soft babbit, antimony, and copper based materials will easily remove with the cloth. You will than need to clean that journal using a clean, lint free cloth. Using an outside micrometer measure the journal top and bottom, and side to side at perpendicular axis to one another. This will tell you if the journal is out of round. Any more than about a .001" - .0015 out of round and the engine probably won't hold a bearing very long. If the journal is out of round, you can wager the rod is also and probably worse. These most times can be repaired also, but it requires cutting the cap and resizing the rod journal end to correct dimensions. If it were me, I'd clean that journal up best possible with engine in the tractor, get a good measurement and ascertain this part before going further. If proven satisfactory for both dimension, and out of round, then rotate the crankshaft 90 degrees, and pull the rod and piston down with a wire around it's base, install the rod cap, and measure the interior at 90 degree spacing basically the same as you did the crankshaft journal. If anything is found out of tolerance, the engine will need further repair. Given the scuffing I see on the other bearing shell you posted, the engine could use a "freshening" which is easy in the grand scheme of things. Citing the engine still has standard sized journals is in your favor for economical repairs, (relatively speaking). I'm interested in what you find out with the measurements. Keep the sump mounted back up onto the engine to preclude any rusting from the humidity in the air too along with catching airborne dirt.
russell
Hi Codger
Thanks for the reply Do you have a suggestion for the grade of emery paper to use i have plenty here but its pretty course i think its about 120 grit . I will have a look at my micrometres i have here im not sure i have one the right size you would kind of think with the bearing halves stuck together that the conrod would have to be out of round but like you said start with the crank. Do you know or would some one else know if its a big job to get engine out of the dozer ? can you remove engine with out removing radiator cheers
Codger
Hi Russell; I typically use 320 Emery cloth when polishing journals. Also use a light machine oil and polish just till a clean surface. I expect you will need another connecting rod but am always conservative on the internet with suggestions as to not paint "doom and gloom" which is so prevalent. I think if the crank journal is found to be good, you can pull cylinder head #1, install a bolt and clipped washer into the block deck to ensure the liner doesn't push out of the block while you push the piston and rod out from the bottom to renew the connecting rod. Hopefully the prognosis is good once the crankshaft is measured up. Many times a rod can be resized, but many times not. I wouldn't attempt to pull the engine with the hard nose and radiator in place myself as it needs to move forward to clear encumbrances to remove. Usually best to lift a little and pull more from the front than straight up. A wheel loader, or crawler loader is a good tool to use for the lifting as everything is heavy. Hopefully you can do an inframe rebuild and all be good. Regardless it will be much easier to work with if the blade and push beams are removed.
russell
Hi Codger
Thanks again i will have to get some 320 grit emery this is a different question if the crank is ok would it be possible to pull the piston downwards enough to get conrod off ? Im not sure if gudgeons pins are press in or just slide in just a thought . I guess the crank journal is the first thing and go from there. Looking at the exhaust manifold bolts they are going to be a big problem nuts are rusted pretty badly i guess i could just cut them of and try remove studs latter. Did ails ever make a tool to hand wind the motor over i have been baring through the timing mark plate its ever so slow any way first job crank shaft go from there thank you for your help cheers
Codger
Hi Russell; Don't know if I've ever seen an engine where you could remove the wrist pin from the piston with the crank still in place. I really cannot say for certain but probably not. Many times those pins will push free with a little force after the circlips are removed from their ends. Sometimes a little more force than fingers is needed and I've used a large "C" clamp and spacer a lot of times but usually a hydraulic shop press is the tool to use. I would get those exhaust studs and/or nuts soaking in 50/50 ATF Acetone mix a couple of times per day. Then a torch to warm the fasteners red, allow to cool, then red again and after a cooling period attempt to gingerly break them free. It would be helpful if a helper were to warm the area around the fastener just before you apply torque to the frozen fastener to expand the direct area. The penetrant works, but takes a while when things are really bad. |
russell
Hi Codger
Had a couple hours spare yesterday started to emery crank shaft i spent probably a hour or so but did not make a lot of progress still plenty of white metal on the crank shaft is this normal? using 320 grit paper wondering if i am doing somthing wrong or its just one of those jobs that will take lots of time cheers
Codger
Hi Russell;
You could start with 240grit but it will scratch deep if aggressive. That bearing has been very hot to be adhered so tightly. Not what I consider abnormal as the appearance from your other bearing shells reveals oil starvation.
russell
Thanks codger
I will do a bit more and see how i go with the 320 probably just one of those jobs that take time |
Codger
It can take some time and elbow grease when attempting to not do further damage. I've seen many engines over the years carry great oil pressure hot and cold but still starve the rod bearings out on supply as they gain clearance over time and usage.
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 890 |
I know Codger has you well covered, I'm encouraged by the one picture of the journal. Measuring the journal with a calliper will be important. What I would add is using plastigauge if you manage to get a hold of a new set of bearing shells. Even if the clearances are critical it may do for an OK bandaid for your dozer. You would need to determine that your rod is acceptable without resizing and yet if that would be a game changer it's worth pulling the head and that one piston. This may be somewhat of a gamble but it wouldn't have to cost you much money...
russell
Thanks Eric
I have not had the chance to get back to the crank i have a lot of cleaning up to do there hope i get the metal of and its ok underneath cheers
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 934 |
I have a neighbour with vast experience of Allis dozers. He owned what would be a candidate for the best working HD 16 DP in Oz - machinery wise, not so much paint and decals.
I talked to him at the ANZAC service today and mentioned your Japanese crank. His comment was that there were 16000 series and 17000 series engines we got here. Seems the 17000 ones came via a particular importer. He described them as "looking like a 16000 but weren't quite" and that he had never followed up in detail. FWIW
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
16000 series is the 3 valve head and would have been out of production several years before the DP tractors were released
ACjack
Silver Level Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 274 |
Thanks(2)
During the time I worked ( late 1969-1973) in department 75 (engine assembly/ repair) all 16000 & 17000 series engines had the 6 count counter weight crankshafts. There was no difference in the crankshafts as-to what engine they were used in. ALL 6 count weight crankshafts were forged in Japan and shipped to the Harvey Engine plant where they were machined. There was no different importers used as to 16000 series vs 17000 series.
After I got into inspection and later became the Customer Product Auditor I had the opportunity to have a conversation with one of the metallurgist concerning the quality of the 6 counter weight crankshafts. He told me that crankshaft had elevated levels of impurities and poor grain structure. Long story short it wasn’t all that great and nowhere near the quality of the U S made 12 counter crankshafts.
Ian Beale
Just remember that Allis also had a plant here in Oz. And the serial number of the Oz assembled AC Forty Five grader we have looks like nothing in the official parts book. I have it "sort of almost" translated by "does it have or not have" various upgrades in the parts book. IIRC the model was "124".
Locally constructed comopnents meant lower import duty. Example was that the Bucyrus equipnent for IH was done by Armstrong Holland under license.
I have no idea what level of assembly the pieces they got were. But businesses weren't above shoving obselete components off to places like Oz. You may think that the last Ford flathead trucks were 1953 - we have one bought new in 1954 - with Lucas electricals. The "Y blocks" arrived about 1955. The neighbour I mentioned has had a lot of Allis experience. To the level of when his 16 DP got sick he took it to a major in the game. And came home with it overhauled and about 40 tons of Allis dozer parts as that major was concentrating on "Komatterpiller". He was very helpful with our grader resurection. And his work is first rate. His (non-Japanese) crankshaft experience was (IIRC) - his was cracked, 2 tagged good were cracked and finally he got a good one. There was a nest of HD 16 and 21 owners in the area and cranks were a barbeque topic. His mention of "one source" for things 17,000 was components being brought in by an importer with South Korean connections. I guess he didn't see many official ones. Edited by Ian Beale - 29 Apr 2024 at 4:00am |
russell
Hello
I have not been on here for awhile busy on farm Thats some interesting reading on the crank shafts I still have not had the time to do any more on my crank shaft work in progress cheers
