Metal cutting bandsaw |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11421 |
Posted: 26 Jun 2023 at 7:26pm |
MK MORSE is a great company, and based in Ohio I believe.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78075 |
I bought a 14 inch vertical wood band saw about 40 years ago. ($200)... Built a jackshaft with couple pillow block bearings and a couple BIG and SMALL pulleys.. Reduced the speed 15 to 1 or better i think.... It was 14 inch wheels and uses a 92- 94 inch blade... I agree with the BI-METAL blades... i dont use coolant...... i need the standup because i cut a lot of smaller parts / sheet metal , and that cant be clamped in the horizontal unit..... but i guess some of them tilt up and you can use the table..
they make some similar now that have gear box and reduced speed for metal... Pushing $1500- 2000.. i think.
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
What band saws do you guys use?
I have looked at this one:https://www.grizzly.com/products/grizzly-7-x-12-1-hp-metal-cutting-bandsaw/g0561 Like the price point but have seen some negative reviews to it being China Built Looked at this JET model:https://www.amazon.com/Jet-414560-HVBS-712D-Deluxe-Bandsaw/dp/B01C9TVZTO/ref=sr_1_1_sspa?crid=37JQJ4WX9U4A3&keywords=jet+bandsaw&qid=1687780243&sprefix=jet+bandsaw%2Caps%2C111&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 More money but probably a little better quality What do you guys think? |
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1819 |
"Morse" brand saw blades are decent to good also and more easily available at the home centers, (around here). I always run coolant so blades last much longer than dry cutting saws.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21584 |
I had two of those 'offshore' 4b6 bandsaws but do to the move now only one... I've used the 'bimetal' blades from one mfr(name I forget..) for 30 years and never had to adjust the 'track' of the blade.Used to cut a LOT of steel years ago, today not so much. bottom line, buy a quality blade,keep 2 on the shelf !!!
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9288 |
I completely agree with Codger. Lenox are very good if the proper blade is selected. |
Codger
I have an HF Wells industrial bandsaw and have found Lenox band saw blades to be about the best if correctly selected for the job at hand. I've ordered from here in the past as well and coolant and such: Edited by Codger - 26 Jun 2023 at 5:41am |
200Tom1
Orange Level Joined: 03 Jun 2019 Location: Iowa Points: 1142 |
I bought myself 1 the other day. It needed the motor rewound and a 3" wheel. Motor is done and wheel is on it's way. This is one of the ones every blacksmith had in his shop back in the 1960,70's, etc. I want to buy a new blade for it. Do you fellows have any recommendations on a blade. I'm gonna order the rubber band "tires" for the steel drive wheels from Amazon
