615 diesel d2200 backhoe won’t start |
Green135
Bronze Level Joined: 08 Jun 2021 Location: Virginia Points: 5 |
Posted: 08 Jun 2021 at 11:28am |
I’m new hoping someone can help I have a late 60s 615 when I try to start it when it’s just about to catch it seems like either starter disengages or engine shuts down I’ve gone through the wiring new battery rebuilt starter at a dead end
NomoreJohnDeere
Silver Level Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
describe more or post a video.........
HD3
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4344 |
Have you bleed the fuel system?
Green135
Yes bleed when I changed fuel filter was running fine then started doing this. I’ve looked in to it more I think it maybe be fuel shut off selnoid gone bad would than cause complete engine shut down ? Wouldn’t it just keep cranking just not start?
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4766 |
You most likely put a seal in the top of the filter where it doesn't belong, then it blocks fuel flow. Does this have the small cartridge fuel filter?
Green135
It’s got fuel supply it was running after I put new filter on just started doing this
nickia
Orange Level Joined: 11 Sep 2009 Location: alden iowa Points: 751 |
i had the same issues with my 615 take a jumper wire and run it from the injection pump to your postive side of your battery and see if it firee
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 887 |
If it stops cranking there is definitely an electrical issue, it shouldn't be the starter if it's just rebuilt. Did you get a new external solenoid? If you boost directly to the starter terminal the starter will not cut out if it is good.
Green135
Haven’t had a chance to work on i will give update as soon as I work on it thanks for all the input
