426 engine |
allis3
Bronze Level Joined: 29 Jul 2012 Location: usa Points: 46 |
Posted: 06 Oct 2018 at 9:53pm |
What 426 allis engines had the German crank in them . Found a coupe of 670T engines but not finding what cranks they had
Orange Level Access Joined: 12 Sep 2009 Points: 19601 |
What is your concern?? Any 670- T engine should have a non-counterbalanced crankshaft in them. That is assuming it's never been replaced with a different crankshaft. Any 1800 RPM gen-set engine has a cheap crankshaft in them because of the application. The best cranks had the small diameter long length bolt holding on the crank pulley. What size socket does the crank pulley bolt take ??
allis3
I don’t have them in my possession yet , was just checking to see if the cranks were the same as the N5. Both of these engines were stationary rigs. Gonna stroke one of them for a big cube class and convert it to gas
They are not an N-5/6 crankshaft as I see it. If they have a fluid vibration damper they are the counterbalanced design. Never have seen a rubber damper on the N-5/6 crankshaft.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6585 |
Say Dr., will the fluid damper work on a non counterbalanced stroked crank?? It has been computer balanced. |
It will work fine. I've had one on a 180 twin-spin puller for many years.
allis3
Anyone have any leads on a 426 head the plugs have been installed in already
Ronin x Part
Bronze Level Joined: 25 Sep 2023 Location: Doral, Fl Points: 1 |
Can someone help me? I am looking for a standard size crankshaft for an Allis-Chalmers 670T motor. Can anyone recommend someone who might have it?
