AC 620 60" cut ability |
Post Reply | Page <12 |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11570 |
Now yer' talkin' peaches n' apples. If you want to do all that other stuff that JP mentioned, then you better nab that 620! You only talked about mowing yer lawn in the original post. Make sure that 620 is in YOUR driveway this weekend! LOL!!
Bird76Mojo
Silver Level Joined: 12 Mar 2015 Location: Illinois Points: 221 |
If you decide not to buy the 620, how about passing the deal along to the rest of us? I'd be interested depending on where it's located.
GB :) |
Ken P
Bronze Level Joined: 28 May 2015 Location: Mid Atlantic Points: 15 |
Thanks JP That's why I want a bigger faster tractor so I can do things like move trailers around and possibly blow snow or even till my garden.
If youre always in control you're not driving fast enough
Ken P
My deck is set up correctly including difference in height from front to rear and my blades are always sharp but I have never tried a "High Lift" blade so as to cut all the grass nicer at a slightly higher speed. If I could do that I would just keep my reliable MTD...actually it is a LOWES. I'm sure you guys know the story of this particular model MTD.
Edited by Ken P - 29 May 2015 at 11:47am |
John Price
Bronze Level Joined: 11 Jun 2013 Location: Virginia Points: 37 |
My Woods mower is a RM59. Wonder what that could mean! It is the same width as the tractor and high flotation tires. It has three spindles and is 2000 RPM PTO driven to a pulley and a hefty belt that must be a mile long looped back and forth and twisted a couple times. The pulley sizes reduce the RPM speed to something subsonic. So far no problems with anything and it cuts like crazy. I hope I do not need to ever figure out how to put the belt on it and I ought to look for a belt routing decal or take several cell phone pictures now! I do need to sharpen the blades for the season.
Zeros are way capable, but can they push and blow snow? Plow and till and blade? Mount a loader or a backhoe? Compete in a tractor pull or simply be as cool as a AC large frame? Don't think so. JP
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3303 |
quality of cut is all about the blades and the correct blade tip feet per second just because the blades have been sharpened dosnt mean that they arnt wore out also the deck levaled with the front of the deck being 1/4" to1/2" lower than the back. canot find my litttle rpm chart for blade tip speed . longer blade less rpm shorter blade more rpm
Steve in NJ
The 620/720 Tractors are pretty cool, and $1500. to me is a great price, but I'm wit' Myron on the zero turn. Those machines are incredible the way they cut grass and maneuver. The landscapers around this neck of the woods rock n' roll on those things. You get two of those things rollin' around here on a 4 acre lawn, and those things will kick that lawns a$$ in no time flat! Next thing ya know, they're loadin' them things into the trailer and away they go to the next house! I'm gonna git' one of those buggers some day. My old finish mower though makes my property look like a golf coarse after I git' done mowin' it. Takes me a good 3.5-4 hrs to do my 3 acre lawn, but it looks sweet when done. Ken's right to. Gotta' keep them blades sharp for a nice cut! My plans are to git' one of them dare Orange Husquvarna jobbies one day to mow wit'. Neighbor down the road has a commercial one and loves it. Does his lawn in half the time I do mine, and he's got more lawn to cut. I might even get Jo Jo to mow the lawn. She sees how fast these Landscapers around here fly! LOL!
Jim Hancock
Orange Level Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1109 |
Ken,
As with the others, that's a great deal! Knowing that there is a hi-lift blade made, I would look to get a set so that they can throw the grass out and not ball it around underneath the deck. I went from a mulching blade & medium lift blade to a hi lift on my Craftsman and it made a world of difference and I scoot right along, too! Also the obvious, keeping the blades sharp and balanced helps a lot with the sickling through it.
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1613 |
Thanks(1)
John Price, which model Woods rear mower, is that the 48" single spindle
rough cut? Is PTO driveline (PTO clutch and internal gearing, bearings, shafts) holding up OK? |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10567 |
I cut several acres with mine. Engine is tired and deck is too. Still cuts faster than any tractor style around these parts.
Any side discharge deck has to toss the extreme closed in blade to the center blade and then to the outside discharge side. lots of grass clippings going out one small opening. A rear discharge deck will eliminate that choking, but it won't look as clean cut. Love mine, just wish they had new engines. Tracy |
macvette
Orange Level Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1656 |
I know what you mean, John. Went on an 1800 mile round trip - down to TN one day, and back home to WI. early next morning. I figure that the tractor cost me $600.00 more than what I paid for the tractor because of the cost of gas for my F-250 V10 gas eater!
But, I really like the unit-big and tough. There have been problems, but the members on this web site are very willing to help solve the problems.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7206 |
A 620 does a good job cutting grass, but don't expect to be finished with your lawn in half the time. While they were made to do a good job, they were not made to do a good job QUICKLY! Also the turning radius on them are probably worse than your current mower.
Much as I love my 620, for your purposes a newer zero turn would probably work best. |
John Price
Nice looking machine. If it starts, runs, steers, moves properly and everything functions properly, $1500 is a good buy. Good luck finding a solid 620-720 with a good functioning deck for any money. And as stated above, $1500 will not buy anything newer that can do what a good, functioning 620 will. I have a nice 720, paid twice what you're looking at but did get a rear Woods mower and a tiller. The Woods discharges out both sides so it handles taller grass quite well. I made quite the trip to get it.......but if you want it, you gotta do what you gotta do. Glad I did, love mine. Good luck.
macvette
$1500.00- I think that if the tractor works properly, I would grab it. Paid much more than that for mine - a 1974. I have mowed grass that is not dry, but not as high as the front wheels, tho - just normal height to be mowed. Works well for me. Usually mow in 2nd gear, and over half way on the hydro lever. We don't have real good grass around here, but it seems I mow at a faster speed than my neighbor does with a comparable size unit, (much newer,but smaller mower deck), plus the AC leaves a very smooth cut. I do not have a rock guard on my deck. My other mower (year 2000) also has a 20 hp. engine, but a 48" cut. Makes a lot of difference cutting 12" inches more each pass with the AC.
It seems that quite a few commercial landscaper/mowers in our area use the zero turns - have seen them cutting in light rain, and doing a decent job - again, just on grass that needed cutting, not wheel high grass. Seems like they are very fast, and of course quick turning.
Edited by macvette - 28 May 2015 at 10:38pm |
BrianC
Also, if you do go for a zero turn, make sure the model you select can actually do what you have seen (tall grass in the rain, mulched to invisibility). I bet many being sold can't do that.
BrianC
Can the 620/720 60" cut taller grass quickly like you see them new high powered zero turns? I say no. Just last week I was cutting juicy green grass (with my 620) about front tire high. The deck can't eject the clippings. I do have the "rock" guard installed. I creep thru that tall grass, and can hear the clippings making a flapper like all wadded up noise, then they finally get spit out , looks like a cow puked. Sort of pathetic actually. The deck also isn't good at sucking up leaves and chopping them. Leaves in a hole or wetted down are untouched. On shorter grass, yeah you can go 60" wide at a good clip. I think your 2 hour time would go down vs. the machine you are using. However, I have a JD 318 with a 46" deck and essentially the same 2 cyl Onan motor as the 620/720/Powermax. It can chop through tall grass and suck up leaves. My 620 can't do like that, even if I take a narrower cut.
On the other hand, the cut looks really good, all them rollers prevent scalping. When I got done cutting, I thought, wow, the place looks like Augusta golf course. Not looking in the direction of the miserable-cutting tall grass. Disclaimer, I bought this 620 used about 2.5 years ago, it seems to be a typical working example, but maybe something is wrong. I have no experience with them when new back in the day. I was considering taking off the rock guard. IF the machine had a 540 rpm PTO I would set-up my little 620 garden tractor as a tractor, not a large lawn mower. Use a 3pt finish mower, 12" plow, 4ft disk, drawbar 6ft rotary hoe and drag harrow. No mid mower deck swap. Something tractor-like and sort of in the same league- Simplicity Conquest XL, John Deere x700 series, or their prior 585,485 , maybe 425. You can get 4wd, water cooling and 540 rpm PTO and mini-cat 1 hitch. Nice are the lawn mower like foot pedals for the hydrostat. Kubota BX's are option also. These machines I just listed cost a mint new, could be $14K. But didn't the 1975 620 cost about $7500 when new? Good luck finding any of the above alternatives for $1500. |
Ken P
here is a pick of it...
Ken P
Good Day All
I have one acre of all grass, it takes over 3 hours to cut. one hour to trim and outline with push mower and two hours to mow with my MTD 18HP 46" cut mower bought new in 1992. I can only cut grass when it is bone dry which is only after 11:00 so it effectively ruins up a whole day. I see guys using newer equipment like zero turn stuff cutting in the RAIN and cutting grass mulching so fine as to not need to pick it up with a sweeper. Also they do it at a much higher speed than mine could ever do and do a decent job. A friend of mine has a 1973 ish Allison Chalmers 620 19.5 HP with a 60" deck. I am considering buying it if the speed makes it worth it and especially if i don't have to have perfectly dry grass to get a decent job.. In all everyone's opinion does this AC 620 stack up anywhere near a newer decked machine in mow speed and quality? or should I stick with my ol reliable but slow MTD and bank on a newer more modern model. He wants $1500 with just a mower deck. Cool looking machine by the way like its got stamina and strength. Thanks in advance everyone |
