5015 Engine rebuid parts
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Topic: 5015 Engine rebuid parts
    Posted: 22 May 2012 at 2:09pm
Does any one have access to complete engine rebuild  for a 5015?  I picked one up a couple years ago, and it is in dire need of a rebuild.  I know Agco does not have them.
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 6:10pm
I believe the Allis model 5015 was really a Hinomoto tractor in disguise apart from the panel work. Hinomoto also supplied the same tractor to Massey Ferguson to make their model ? Hinomoto was sold to Hitachi so Hitachi or MF dealers would be a starting point if you have the engine model ID.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 7:09pm
Kiwi is right on what he is saying
mf 1020 i think but Bombardier
also used the same engine and so
did a lot of what they call the gray
market
head gasket toyosha cs100 3cly diesel
Bombardier  # j60711111001
ARCO      #  72100700
MF   #  3435113m3
Type:Toyosha CS-100
Fuel:diesel
Aspiration:natural
Cylinders:3
Valves:-unknown-
Bore/Stroke:2.874x3.15 inches [73 x 80 mm]
Displacement:61.27 ci [1.0 L]
Power:18 hp [13.4 kW]
Cooling:liquid
Coolant:3.2 qts [3.0 L]
Compression:22.5:1
Rated RPMs:2500
Starter volts:12
Oil capacity:2.3 qts [2.2 L]
hope this help if i can be of more help
let me know
B:-)     Dnoym
LOGOMPV
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 7:34pm
here a few more place  that used them
Simplicity 9518
Massey Ferguson Model 1020
Hinomoto E2302, E204
Allis  Chalmers 5220
http://www.stevenstractor.com/parts
/compacts/massey-ferguson/engine-
parts/head-gasket.html
HTH  B:-)     Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 4:34pm
Thanks everyone.  Looks like I may be able to get a head gasket and take a look.  May be able to rework the head and injectors enought to get a few years out of the 5015.  Main bearings are definitely very scarce, based on the info available.  Thanks again to everyone that responded.
frigget View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frigget Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2013 at 12:47pm
Im wondering if anyone has been able to locate engine bearings (main and connecting rod) for the Allis 5015? Ive been told that the engine manufacturer went bankrupt and can no longer get parts. Is this true? Where can I get bearings? If they are truly not available, is there a place that I can cross reference them? Any thoughts will be helpful, Thanks
3rd generation Ora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Ora Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 8:30pm
Frigget, did you ever find bearings for your 5015 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 9:10pm
Frigget was last online close to 3 years ago.  We will never know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Ora Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 9:14pm
Lol! Grabin at straws I guess?!
ACwd15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACwd15 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 8:11pm
I need a bearings for mine as well.
