a couple photos
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Topic: a couple photos
    Posted: 30 May 2010 at 8:17am
Couple photos I hope.
7020 on a White 6100 and a 7060 on an AC 2600
this is a before shot
21 feet of 2600 disc takes everything the 7060 has.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:36am
Hey Russ, How do you see the row markers in no-till?
I don't think my WD45 will pull that disc! lol
Don
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 4:15pm
   Ahh, Don that 45 will walk the dog with that disk. (As long as you don't put her in the ground) LoL !
http://www.rumelyallis.com
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:47pm
Russ,  With your 7060 and 2600 disc are you limited by hp or traction?  Also are you running duals, radials, etc?  We would like to get a 2600 disc someday but want to make sure we can put it.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:22pm
Basically very even match of power and traction. Running Michelin XM108's  650RX38 singles, no fluid, 12 psi, last dyno test showed right around 165 pto hp,  4th gear,  not quite enough to get 5th on chiseled ground, we are fighting some hills. Disc wheels are "clear up", so the depth of cut is possobly more than necessary but this is a "new to us" farm and was a mess.  Since we went to the low pressure, no fluid radial I feel the traction is better, and no "power hop".
I would say the 7060 is a minimum for this disc in my conditions.
24" blades, and they are nearly new.
This page was generated in 0.154 seconds.
