WD hand clutch |
brenpak ![]() Silver Level ![]() ![]() Joined: 22 Dec 2013 Location: Wisconsin Points: 134 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Mar 2016 at 7:02am |
Is there a way to adjust the hand clutch so it is not so sensitive
I mean as soon as I pull the handle back a little it starts to move forward real quickly Just asking Thank you |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21838 |
Make sure the compartment is full of oil. Other than that, you may just have to get used to it.
Ok I can understand that the WD is new to me so maybe I have to baby the hand clutch
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
You could pull the pin at the bottom of the Lever, loosen the lock nut, and turn the yoke a few turns to shorten the Rod. That way the Lever should have some extra free travel before the clutch starts to engage. Gary |
Ok I will try that thank you
