1954 allis chalmers b
phranquenstein1949 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phranquenstein1949 Quote  Post ReplyReply Direct Link To This Post Topic: 1954 allis chalmers b
    Posted: 26 May 2010 at 2:54pm
just figured out how to post an image so here goes.  this is the model b that I would like to buy and am looking for an approximate value.  i have no clue as to the value.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 3:12pm
Does it have snap coupler?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote phranquenstein1949 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 3:44pm
Lets say no because I don't know what that is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phranquenstein1949 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 3:46pm
where would it be and what function does it serve?
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 4:03pm
A snap coupler is a type of rear hitch. It will have two lift arms sticking out of the rear, and a bell-shaped reciever under the belly of the tractor. This bell-shaped reciever should be right under the transmission, or in the general area. Some Bs may have had a pin-hitch, which is similar. Pin hitch reciever does not have the bell. Both types of hitch recievers have a big spring that runs diagonally in the middle of the reciever. The implements have a tongue with an eye that engages the snap coupler bell under the bottom, and two chains that lock into the rear lifting arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 4:05pm
Ther's something under the belly of your tractor, but I can't tell what it is. Picture gets too fuzzy when I blow it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 4:14pm
Dream, the B snap couple bells that I have seen bolted to the drawbar after it was turned around backwards. B's didn't have a "pin hitch" like the early CA's as far as I know either.
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 7:41pm
DON'T LOOK LIKE A 1954.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 7:49pm
What doesn't look like a 54? It has electric start,foot brakes and a distributor.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 7:59pm
I have to agree with C Tucker.  Snap Coupler B's were as scarse as Hen's Teeth.  I frankly never sold one.  In our area they wanted CA's for two plow work.
In any event if it does have snap coupler run don't walk and pay the man what he wants.  It is that valuable.
Others can give the normal price for the tractor.  When you get it take good care of my favorate.
Good Luck!
Bill Long
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 8:25pm
Wouldn't have snap coupler as the Woods mower deck that is on there now takes the spot of the draw bar. Need more info to tell value. Location, Implements, etc. We can't just put a price on a picture. If I were buying it I would ask to see it out of the shed operating. This includes mowing.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 9:47pm
Guys,
It is an estate tractor. Given that it was family, I'd go higher than normal if I were you.
If it runs - $1000 to $1500 with the mower, if it don't - then figure $400-$900.
JMHO
This page was generated in 0.093 seconds.
