Opinion of rotary hay rakes |
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1031 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Feb 2016 at 3:57pm |
Farm auction coming up close by has a like new Kuhn GA 3200 GT single rotor rake. My main concerns are:Does it make a neat windrow with the curtain on it? Does it shatter leaves off legume crops? Is it high maintance? Thanks for any help!!!
chevytaHOE5674 ![]() Orange Level ![]() Joined: 21 Apr 2010 Location: DA UP, Mi Points: 260 |
Makes one of the best windows of any type of rake there is; they are uniform, tall and fluffy which allows lots of air to pass through and get the hay nice and dry. Also one of the most gentle types of rakes there is because they sweep and release the hay into the window.
Yes they are high maintenance, they have a ring and pinion gear as well as each rake arm has a bearing and arm on the end that rides in a cam track that gives the rakes its motion. If its been taken care of and everything is good and tight then you will love it, if its been abused and neglected it will make a preacher cuss. |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8733 |
The only thing that I found I don't like. I find it missing some hay in fields that have a lot of on level spots. But I also agree with everything Ryan says
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
All the above is true. We are on our second one first was a Kuhn and had lots of issues with it. Second is a Victor same as a Miller Pro and love it. |
bauerd44 ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
We bought a used Vicon rotary in 2012, and it is the best we have ever had. The only area that it will leave hay is in a shallow dip. It will make some of the tallest. fluffy windrows I have ever had. Now I wish I had a twin rotary so I could get done raking sooner.
Dale |
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
Kurt WI ![]() Orange Level Access ![]() Joined: 19 Oct 2011 Location: Cascade WI Points: 3242 |
We got a Kuhn rotary rake it works great!! Dont remember the modal number but the weak spot is the roll pins on the raking arms! On on even ground it doesnt seem to follow the contours and digs in resulting that the roll pins snap!
WD D17D 170 190xt 190xtIII 200 7020
Johnwilson_osf ![]() Orange Level ![]() Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 941 |
We use that model rake, and love it. The only thing that can be tricky to get figured out is the speed. If I run at too high an RPM, I can toss the hay in front of the curtain. So once you get used to the right speed, you will find an incredible windrow.
John |
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
Longmeadow Farm ![]() Silver Level ![]() Joined: 30 Jul 2011 Location: Eastern NY Points: 321 |
I own a S&K 11 something. It has a tandem axel and I believe it's a Miller Pro rebranded. It took some time to adjust ..it's best if you have a level concrete pad. I adjusted the rotary to miss the ground per the manual. I leave a stubble of at least 2.5 inches , which helps reduce drying time. I run my rake per the manual..PTO speed wise... and it produces high fluffy windrows that sit on the high stubble and dry rather quickly in the summer breezes. My hay ground is a mix of grass-clover and grass-alfalfa... with some fields approaching 50% clover. I rake the hay a bit green and allow it to dry in the windrow... with little to no clover leaf loss. I don't use a hay tedder ... as my disk mower conditioner is one of those that can produce a wide swath of hay...for quick dry down. The tandem axle allows the rake to traverse uneven places without much if any loss of hay contact, the teeth show no appreciable sign of wear after 8 seasons of use and I haven't had any maintenance issues. It is my judgement that using a single raking tractor lets you adjust the rake to that particular tractor..and then it's rather easy to just hookup and go. This is especially important when you use hired help. I've used the rolabar and wheel technologies and while the rotary may not be the fastest .. I'm not in a race anyway.. it does produce the nicest of windrows to feed a round baler. Each machine will have its quirks..so it's best to study the manual and observe its in-use operational characteristics and go from there.
michaelwis ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Wi Points: 8765 |
Also own a Kuhn ..since 1979 With no issues.none Was told to grease often..and we have The trick is with a 3point model to make sure the table is level |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
NickT(Ky) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Elizabethtown, Points: 417 |
Ky Allis, there are hay brokers that buy and ship alfalfa to Europe that will only buy the hay if raked with a rotor type rake. No wheel rake. I use dual bar rakes but have been entertaining the idea of getting a rotary rake. But I do use a tedder in the first and sometimes second cuttings depending on crop density. p.s. I still have and use that Deutz/allis discbine I called you on for advice on a repair once. Thanks again. Nick
Al in WMA ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: Massachusetts Points: 158 |
We wouldn't be with out our Kuhn rotary rake, Pretty much the standard around here.
Education is what you get when you don't get what you wanted.
