715C Backhoe forward clutch dragging
brouillettefarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brouillettefarms Quote  Post ReplyReply Direct Link To This Post Topic: 715C Backhoe forward clutch dragging
    Posted: 18 Nov 2015 at 1:31pm
I just purchased a 715C backhoe and the forward clutch seems to be dragging, when its in neutral it wants to pull forward, and when your in forward and hit the clutch pedal it still goes forward, when in reverse it labors very hard to move in reverse and when you hit the clutch pedal it starts pulling forward, any help or advice would be greatly appreciated
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 1:40pm
It is a piece of and that is why Groffs bought it. I know where it came from and knew what was wrong with it. And Max knew it when he bought it that way. Gave the farmer 5000 for it. If you look at a post down a ways you will see my nephew asking about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 4:07pm
get the manual - sounds like hyd pressure or clutch pack problem
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 4:30pm
We can rebuild it or sell you the parts to rebuild it 989-379-2721
