PTO on a dozer why
OldSchoolRecovery View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Topic: PTO on a dozer why
    Posted: 16 Nov 2015 at 10:38pm
Ok, dont hammer me too bad, but why?
Unless for agriculter, Im not sure what use it would be.
I do have farm tractors with pto rototiller, flail mower and manure spreader.
Some examples would be nice.
My new H3 has a pto if you havent guessed allready..
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 10:40pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 11:35pm
With a pto, you have a the ability for many other attachments. besides running an elevator or buck saw or a water pump or a hydraulic pump or mower... or even attach a logger boom behind it and winch in logs and lift them... etc.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 5:12am
I've used the PTO on my H-3 to run a belt conveyor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 5:47am
My grandfather's D2 cat had a belt pulley, on the back, we used it on the farm, to grind feed with...
When I ordered my struck MH5000, I made sure to get 3 point and a PTO, makes it a pretty good stationary power unit, much more versatile...
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 8:32am
baling in the hill country :)
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 12:58pm
My HD-5 has a belt pulley. We run the sawmill with it in Lesueur. Our HD-3 has PTO and 3 point hitch. Why not? You never know when you will need it.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 6:20pm
even 200- 300 HP tractors were ordered with winches (PTO) from the factory.. Military had a lot of them.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 7:39pm
I used the one on my hd4 for a post hole drill.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 8:53am
An HD-3 with a 3pt and pto that sounds perfect for mowing multiflora rose.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 10:42am
could have also pulled a combine on the hills out west
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 11:54am
Probably part of the reason of finding them on the older crawlers is that like others said they were in the day marketed for farming in certain areas as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 10:36pm
Anyone have a picture of 3-point hitch on a H3, thanks,
cb1
fifacome60 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fifacome60 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 9:11pm
I was only lucky to score these goals," Huang said modestly. "I didn't plan to score in a certain fashion and what I was mostly thinking about was setting up goals. But the goals came naturally when I tried."
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 9:32pm
My hd-6 has a belt pulley and pto.
This page was generated in 0.172 seconds.
