a c planter monitor
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: a c planter monitor
    Posted: 04 May 2010 at 11:17pm
my planter monitor has a light on that says low voltage this came on last year at the end of the season this yr i put the planter on another tractor and got the same light this tractor has new batteries and charges well i even ran a set of jumpers to the tractor batterys to make sure they had a full charge but light still stayed on. all three fans run fine any ideas?  from what i seen last yr when i planted with the light on it planted fine. contune to plant or does something need looked at?  Thanks Nick
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 11:23pm
Check your power leads from the batteries to the monitor itself.  I had to redo ours..it was about frayed in two.  Would cause the monitor/blower motors not to get enough current...and not have enough air to hold seed in seed discs.  Just remember, three fans are pulling a good bit of current..have heard of people swapping out their alternator for a bigger one just for planting season.  and...make sure all your connections are clean.   -Wes
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 11:24pm
sounds like a bad ground on that row. most of the dealerships have testers for your monitors, might try that. also i am parting out an air champ 4-row. it has a monitor.
This page was generated in 0.159 seconds.
