Torsion Bar and Linkage |
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Sep 2015 at 8:17am |
Hey Guys,,,The PO of my D15 II had welded a humongous hitch on this piece and it also had some pieces that had broken off and some that were cut off way back when. I never could get the AGCO parts books to open using IE,, so I downloaded Firefox and problem fixed. (sent MS a nice email letting em know),,,The accompaning pic is my first try with "Snipping Tool" and hope it works,,,here is what I got,, 1. Piece #18 (PIN, draft arm & sway chain anchor)is stuck and no amount of heat and BFH will convince it to come out, will need to get on a BFP (press)! The other side came out with normal heat and beat,,,, 2. The PO had torch cut the ends off both of these PINS so I have no idea how long they were originally. The pic shows threads on both ends,,but what pitch? 3. On piece #19, what hooks on to tab looking up on right end? 4. I had to replace the broken off 3/8" pin on left end of piece #13. It hooks on to the long rod that hooks up to the lever under hydraulic reservoir. 5. I do not find a dwg in the parts books that shows the arrangements where and how the "sway chains" attach. Thanks for any and all help,,, CHIT,,,can't get pic to upload,,,, OK,,had to download software to convert PNG file from AGCO to JPEG,,,,sheesh,,, ![]() Edited by desertjoe - 13 Sep 2015 at 8:47am |
# 11 hooks to lever sticking up. MACK
OK,,,Thanks for that info,,Mack. On the two #18 "pins" these weren't pressed in were they? Gosh, I have had piece #19 red hot and made a jig in the big vise and still will not break loose,,,!!! Gonna take to a friend's shop who has a BFP and see if it will break loose,,or ruin it,I guess,,,,,I've had this piece hot so many times,its prolly harder than Shameless's head and will not be able to drill the piece out now,,,, Can anybody supply me with some dems for the #18 pins and the thread pitch on both ends,,,???? Thanks for the help. ![]() |
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
I gots sum baling wire
baling wire,,,,????,,,,,,,Shameless,,,it's the baling wire philosophy I'm tryin to fix on this tractor,,,,,!!!!! ![]() There seems to be a big lack of info on the operability of this system on the internet or I ain't holding my mouth just right,,!! The only video I found on youtube is one with a small girl trying to read from a procedure and she don't understand it either,,,!!! I would like to read up and understand how it works so I know how it affects the hydraulic pump output and adjust for it. You got one of them books in your back pocket?,,,,,, |
Not sure, but think they have a taper on them. MACK
