brakes on a wd 45 ?
Maurice/Pa. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice/Pa. Quote  Post ReplyReply Direct Link To This Post Topic: brakes on a wd 45 ?
    Posted: 13 Apr 2010 at 6:44pm
      How do you get the bands out of that small opening? Is there a pin in the bottom that has to be removed?
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:52pm
Yes there is. Do you have a torch, a welder, and a jack hammer? I hope yours is one of the easier ones. I welded a nut on the end of mine, then made a puller to get them to move. Some people just go in from the bottom of housing with a torch and cut em. Find new ones first. Not impossible. Good luck!
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:59pm
Been soaking one of mine in Kroil for 1 week now, scraping rust away from pin and forcing it in as best I can. Tried shooting Kroil from top down inside band cover, can't tell if that's hitting anywhere good or not.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 7:53pm
Good idea to have your tetnus vaccination up to date. Mice love to camp in the brake houseings.Plenty of opportunity to bang a knuckle . Get a manual and good luck.
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:04pm
Just did my first set this winter on a WD one took two full days and a lot of heat, the other one slid out in about an hour. Have fun and good luck.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:18pm
I wonder if the engineers that designed those brakes kept their jobs till retirement!! LOL  That is a p*ss poor design.  Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:24pm
Ryan, if the brake bands were renewed every couple years it would be fine. They just designed a brake that was to good, so the pins can rust into place.
