looking for a cckb carb
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: looking for a cckb carb
    Posted: 01 Mar 2015 at 3:42pm
looking for a good carb to rebuild. the one on my motor does not have a return port so if I can find the correct carb cheap I will buy and rebuild otherwise I can just plug the extra port on my fuel tank.
Thanks!
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 8:37am
Dave,
There's a guy on e-bay bustin' up a 4040 power max. He might have a carb if ya e-mail him. Didn't see it listed, but ya never know. Maybe he didn't get to partin' the engine yet... Worth a try..
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 9:16am
Sweet thanks Steve
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 11:59am
The carbs don't have a seperate return port but have a T fitting on the fuel inlet for the supply and return lines.   Haven't looked at one for a while but believe the return line side of the T fitting has a smaller hole inside as a restrictor to ensure the carb gets fuel first.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 9:19pm
any idea what the thread size is on the carb? I'm going to run an electric fuel pump so I wouldn't think starvation would be an issue but I can always choke it off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 9:27pm
You will need to return the excess fuel back to the tank. A tee fitting and a fuel shutoff valve will work well. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 8:24am
I believe the inlet is 1/8 or 1/4 NPT. I'll havta' take a look at my carb and let ya know fir' sure. There's quite a few electric pumps out there that are adjustable down to like 2 psi that should work for your application. How'd ya make out with the e-bay guy? Did you e-mail him to see if he had a carb? just curious.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 11:48am
The carb is 1/8 NPT. I have (1) NOS left.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
This page was generated in 0.209 seconds.
