Snow blower to fit 720
Pat SW Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat SW Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Snow blower to fit 720
    Posted: 11 Jan 2015 at 9:00pm
I found a snow blower off a Simplicity 5216 which is the same as AC 616, I understand. Now if all this is true would this snow blower also fit on my 720?
Any input appreciated and thanks.
Pat
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 9:03pm
Yes it will fit.  Hope you got the mule drive to mount it...hard to find and would be interesting to build.  Good find, Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 10:58pm
The 5216 is a small frame lawn tractor with 18" rear rubber. Yes its the same size as the "616 special" which was a lawn tractor. It will not fit a 620/720 Powermax. The blower is likely only 36" wide and is belt driven. I would think the 720 uses a shaft drive blower?
Edited by ACmowerguy - 11 Jan 2015 at 11:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2015 at 4:18am
I now agree with mower guy and not with myself.  I was under the impression that the AC match was the large frame 616.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat SW Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2015 at 7:06pm
You guys are correct. The Simplicity snow blower I found would fit the 600 series tractors and not the large frame 616, 620 and 720 tractors. This can be a little confusing. Thanks for your input.
