AC 716H NOT RUNNING RIGHT
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: AC 716H NOT RUNNING RIGHT
    Posted: 29 Sep 2014 at 9:00pm
Our 716H is running rough. Have changed plug, air filter and in line fuel filter. The engine was running fine then stalled . Not sure if the gas is enthanol blend that is in the tank. Going to try Shell VT 91 octane in the morning.
Any suggestions on carb settings.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2014 at 6:55am
It could be the gas. I've been reading articles and talking to power equipment people about how the Ethanol has been creating havoc on small engines and their carbs. I was told the small engine world is moving to EFI and getting away from carburetors...
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 10:51am
check the spark and clean and adjust points file or replace re gap
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 11:10am
k341 battery , coil ignition  points gap.020 spark plug gap .035 m16 magneto ingnition air gap .014 plug gap .025
