A/C 3500 generator 60kv
joekbyme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joekbyme Quote  Post ReplyReply Direct Link To This Post Topic: A/C 3500 generator 60kv
    Posted: 15 Aug 2014 at 4:17pm
I am working on a 1985 3500 60kv genset.It came to me with the fuel tank and injection system filled with water.I thawed out the entire machine.Had the pump and injectors rebuilt.I reinstalled the pump at 28 degrees.btdc as it was when i removed it.The unit smoked but not to bad.It had no power under load.I pulled a comp test found #4 weak #5 40 lbs.Pulled the head these two pistons were melted the other 4 perfect.I pulled the engine and installed an overhaul kit .Had the head done.Reassembled and started.The engine smokes more than it did before.No longer white,light blue wet fuel smell like a cold two stroke detroit.It does not improve with operating temp increase.What is the correct timing procedure foe this engine? I have had no luck in finding manuals.It also cranks longer than i would like to start. Thanks joekbyme
kyme
Edited by joekbyme - 15 Aug 2014 at 4:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2014 at 9:29pm
Which injection pump is it??? Stanadyne/Roosa-Master??....or American Bosch ?? pictures would be nice.
cw utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cw utah Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 3:56pm
I have a model 3500 Allis Chalmers engine in a 60 kw gen set also. I just got it and am in need of any information I can find. Would you have time to tell me what you know about this unit.
Carl
801-330-7393
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 5:14pm
Original poster might also have injectors installed backwards as they should be Bosch injectors in 1985. They will fit either way, but only one way is correct.
This page was generated in 0.223 seconds.
