installing wick in c crank
murphy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote murphy Quote  Post ReplyReply Direct Link To This Post Topic: installing wick in c crank
    Posted: 10 Mar 2010 at 11:18am
thanks for your responses guys, the clutch was a mess from excess oil so i replaced rear main and wanted to do wick in the crank, question is how do you talk that thing back in there? thanks for all your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 11:34am
most use a sealed bearing and just put a pipe plug in instead of the wick, lot more modern fix and it works better.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 3:00pm
What tractor - engine
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 4:04pm
If I read the post correctly, the engine is the CE engine in a model C Allis. Worn out wicks, or wicks not properly installed have resulted in many oil soaked clutches and/or oil puddles on the garage floor. I now do what Coke recommends. Plug the crank hole and install a sealed bearing. Cost to replace the bushing with the bearing is similar to the cost of a new wick.
Tom IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 7:27pm
Do they make a bearing to replace bushing in a C. Or do you have to have the hole resized to accept the bearing, doesn't look like enough room for a bearing in a C like the
WD has.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 8:26pm
Yeah, give us some tips on how to do this. I walked into the shop last night and noticed that my C had "marked her territory" under the bellhousing. Not sure yet if it's coming from the rear seal or running down from behind the oil filter housing. Bet it's both. The more I run her, the more leaks she comes up with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 6:04am
Tom ,I use the oil lite polit bushing out of a A Farmall and just use a small freeze plug to plug crank.
This page was generated in 0.111 seconds.
