WD Hold position
Bill in Md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill in Md Quote  Post ReplyReply Direct Link To This Post Topic: WD Hold position
    Posted: 13 Feb 2010 at 7:25am
I am having trouble with the hold postion on my WD.  Everything is set correctly acording to the book but the back blade will drift up or down slowly after it is set. i am thinking it is a weak spring or dirty seat for the ball in the valve. Has anyone else experienced this?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 7:42am
Bill, It sounds like it's set to DrawBar control or some call it weight transfer. Have you tried setting it to the hold position? In Drawbar control it will come up just like you are saying. If it's set in Hold position then rest the "A" screw up about 1/4" on the housing and see if that helps.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill in Md Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 7:45am
it is set to hold position acording to the book. i will try adjusting the A screw. thanks Don.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 7:56am
Bill, There is a little dimple in the side of case the "A: screw seats into, If you need to move it up to make her work then readjust the linkage a little.
Don
jjwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjwo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 9:09am
We have had to replace a couple of the hold controls. On top of the pump, not the whole pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill in Md Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 9:50am
what goes bad on the hold valves? there's not much inside; spring, ball and seat, cam. can they be rebuilt?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 10:09am
I've been having the same problem with my WD. It uses to be fine, but last spring I used the Snap coupler plow and reset for draft control. After plowing and re installing drawbar, and setting all controls back to where they were, I  can't seem to find a hold position that holds without floating up or down.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 10:35am
Guess we have to remember that the WD is anywhere from 57 - 63 years old.  Things are basically build well but over that period of time they wear.
Yes, it is just a spring and a ball but I'm sure that can wear too.  When we rebuilt them we always tapped the ball using a flat punch to seat it.  I think it was just superstision but that may be the thing to do now.
Let us know how it works.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 10:37am
Hey Bill in MD tell me where you are in Maryland.  I may have asked before but forgot.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill in Md Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 11:23am
Bill - Im over on the eastern shore outside of Ridgly.  Im not complaining about the old girl. She has dug me out of over 50 inches of snow and pulled a bob cat out twice  in the past week. i was thinking of getting a set of  the cylinder stops to control the depth of the back blade that tractor supply sells.
This page was generated in 0.172 seconds.
