AC D-21 8000 lb class |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: AC D-21 8000 lb classPosted: 18 Aug 2013 at 1:19pm |
Sam Good winning the 8000 farm stock class
[TUBE]http://youtu.be/eLP18GyagsA[/TUBE] |
Charlie
7040
Joined: 11 Aug 2013 Location: newglarus wi Points: 418 |
Posted: 18 Aug 2013 at 1:29pm |
great video thanks for sharing
cottonpatch
Posted: 18 Aug 2013 at 2:11pm |
that looks farm stock.....not
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
2wise4agm
Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Posted: 18 Aug 2013 at 3:14pm |
8000 lb????
Charlie175
Posted: 18 Aug 2013 at 4:10pm |
yes, 8,000 lb class.
Charlie
2wise4agm
Posted: 18 Aug 2013 at 4:56pm |
Never seen a d21 get that light around here.
Posted: 18 Aug 2013 at 5:49pm |
Sammy Boy had the gear and the front end weight figured out just right.
timmypuller
Joined: 01 Apr 2013 Location: wardsville,mo. Points: 125 |
Posted: 22 Aug 2013 at 8:18pm |
my d21 weighs 7530 lbs with me on it and i weigh 215 lbs. we pull in the local farm pulls in their 8 mph modified class. if i take off my center weight racks and 2 outer deck plates it gets down to 7490
2wise4agm
Posted: 22 Aug 2013 at 8:54pm |
Dang! My 190xt weighs about 7300 with me (200 lbs) and that is with no pto housing, a 200 front bolster, cut off front axle knees and only one battery. Most d21s here pull in the 10500 class. Although most are series II. Are the early ones lighter?
timmypuller
Posted: 22 Aug 2013 at 9:05pm |
mine has no pto ,pressed steel wheels with 20.8 x38 tires and the frame off the old "dennis the menace" d21 a d17 wide front weldedon it. also no 3 point and factory fuel tank removed and replaced with a 5 gallon aluminum fuel tank. it's no beauty but it's very competitive around here
Charlie175
Posted: 23 Aug 2013 at 7:03am |
Charlie
DougG
Posted: 24 Aug 2013 at 8:46am |
Nice tractor
