AC 6080 |
Western Maine ![]() Bronze Level ![]() Joined: 13 Jun 2012 Location: Maine Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jun 2012 at 5:56pm |
I have a 6080 that needs the drive shaft seals for the injector pump, they are a cup type seal. Can some one tell me where I could find them?
Thanks Brian |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8308 |
Agco , or any injector pump shop should have them
I got the seals now the tractor only runs a minute or two.
What I found was on the injector pump it's a Roosa master, If I loosen the 1/2" plug on the side it will run fine. I believe the return line may be plugged. Can any one give me some insight where to start ? Thanks Brian |
Look ontop of the injectors and theres the return line , id remove it completely and blow air thru it then loosen the tank cap and blow thru the plastic line returning to the tank ; sounds like you may still have air in the system , if you loosen two injector lines and get full fuel thru them then tighten,the engine should run then you can bleed the other two , 6080,s are a booger to get all the air out
I got it running. The tee fitting on top of the injection pump has a little be be in it and it was plugged, I got it cleaned out and away it went
Thanks for the help Brian |
It is time to remove the pump and have the weight retainer replaced. The rubber from the retainer pluged the check valve. MACK
