390 HAYBINE SCRAP OR REPAIR
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: 390 HAYBINE SCRAP OR REPAIR
    Posted: 04 May 2012 at 9:44pm
I HAVE A 390 AC HAYBINE WITH BAD WOBBLE BOX. IT'S PROBABLY WORTH MORE IN SCRAP IF I CAN'T FIND A WOBBLE BOX. ANYBODY INTERESTED IN ANY OF THE OTHER PARTS, BEFORE IT GOES.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2012 at 10:34pm
I wish I had one. I would make from scratch a wobble box that would last. It can be done, I have done much harder. Can't find one close enough to get. Tracy Martin
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2012 at 10:46pm
While we are on the subject of AC haybines,I believe they made 3 models-904,829 and 390. Does anyone know what order they were produced in?  - Just curious - And was there  one that was better than the others or did they all have wobble box problems?
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 5:42am
The 829 was first made from 1966 to 1968 and it had a pitman arm drive for the sickle similar to the drive on the 90 all crop harvester. The 904 came next made from 1969 to 1971 with the wobble box drive. The 390 was last made from 1972 to 1975 also with the wobble box drive. The wobble box was the weak point in both machines. The entire hay and forage line was dropped in 1975. I have one of each model and my personal opinion is if they had adapted the twin wheel drive to these machines they would have been a much bigger player in the market.  Don Jr.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 8:40am
I saw one (390) at an auction that was converted over to a John Deere wobblebox off an 800 swather. It didn't look like it would be too hard to do if you have a welder to make some custom mounts. Parts availability for the JD wobbler would be much better.
Edited by AllisFreak MN - 05 May 2012 at 8:42am
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 6:27am
Is the wobble box used on any other A-C machine such as the corn head on a 780 forage harvester?
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 6:57am
Would a SCH Pro-Drive box work on that?
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 8:50am
How much do you want for it instead of scrapping it?
Matt Folkers
FOLKERS RESTORATION
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 8:24am
If you run a search on the forum under my name or 904 wobble box you will see the lengthy disucssion on wobble boxes.  I myself am looking for one also.  Someone last fall indicated a wobble box off of a 720 chopper corn head would fit but I have not been able to confirm that.  I do know the 409 and 390 boxes will interchange although the 390 has exterior improvements at the mounting ears.
Edited by Michael (WI) - 07 May 2012 at 8:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 9:01pm
YOU GUYS ARE WANTING SOME PICS SO LETS TRY THIS. I FIGURE IT'S WORTH $300. I LIVE IN NORTHERN MN.
