Wd45 oil line
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 oil line
    Posted: 23 Apr 2012 at 3:25pm
I noticed a small split in the oil line running from the oil pressure guage to the block could tat explain low oil pressure?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 4:09pm
If that crack is leaking enuf to cause a drop in your oil pressure (assuming your tractor is producing good oil pressure) you would have one heck of a mess all over the side of the block. If you have a crack in the line and it is not leaking, you definitely have very low pressure for some other reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 4:24pm
It just slowly leaks out I have low pressure
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 8:13pm
You can still get the lines from agco.  I bought one of the smaller lines - oil filter to head with new nuts and it was under $20.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 10:26pm
I bought an oil line in a package at Advance Auto Parts. It comes in a roll with a bunch of fittings. About $12.00. I needed to run an new line on the D15 to the oil gauge and all of the fittings that I needed were in the pack, including the 1/4" pipe to oil line compression. Bob
This page was generated in 0.048 seconds.
