I pulled my first sleeve
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: I pulled my first sleeve
    Posted: 21 Apr 2012 at 5:46am
today all by myself! First time for everything. It went well and this morning my Mechanic is coming to check bearings, journals, condition of an all original engine. When I measure the crank and rod brg it appears to have no wear on standard parts...2.3725" for both...but maybe that's just what I want to see lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 6:37am
Step #2.....immediately after removing the connecting rod cap with the crank rod journal down,  place a piece of electrical tape over the oil hole in the crank to keep out any dirt. If any dirt falls into the oil hole while you are working on the engine, it will wipe out the rod bearing when you start the engine up for the first time after work is completed. This is one thing I promised employees years ago I would fire them for if they didn't do it.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 7:12am
When somebody pulls a sleeve I always think of Pop. When we were doing an overhaul we would remove the engine, set it upside down on 2 x 4s, put a 4 x 4 on the sieve and call Pop. He would take an ax - flat aide down - to the 4 x 4 and drive out the sleeve. That was some 50 to 70 years ago. Engines were newer then and you could do it. Not now.
Good Luck!
Bill long
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 7:18am
Great pic's cap!!! Were the dogs suppervising the whole time? The sleeve pulling op pic's are a great referance for others-- a picture is worth a thousand words.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 7:19am
First thing I thought of was my friend Armand. He's been pulling the sleeves off his shirts for years.LOL
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:36am
[QUOTE=DrAllis]Step #2.....immediately after removing the connecting rod cap with the crank rod journal down,  place a piece of electrical tape over the oil hole in the crank to keep out any dirt.
Great advise Dr. Allis.  Never thought about the electrical tape.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 10:27am
Did you make the puller tool? Great advice on the bearing. Go the distance Dana, its a field of dreams, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 12:19pm
Thanks for the tip Doc A. I did that and when my mech showed up I told and showed him. He said WOW he would do that from now on. He miked and said everything was good. He always puts new rod bearings on when apart even though they mic ok. Mine are standard with no apparent wear. He said with no ridge in the tops of the sleeves he thinks somebody's been in there within the past thousand hours. My wishbone anchor bolts were 3 different sizes outta the 4 bolts and my oil pan gasket had cement on top and bottom so I think someone had been in there if the factory never glued both sides; did they? Anywho I will put back together with new standard rod brg, sleeve, piston, rings, wrist pin and clips, all new top end gaskets, oil pan gasket. When the shop finishes the valve job she'll be tested again. If she doesn't purr like a growlin' kitty then...the pump man's gettin the pump back.
BCPuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 3:04pm
What engine is this? look like flat top pistons?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 4:57pm
Looken good til picture #3 Captain, That one kinda scaryBig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 4:59pm
Cappy and Dill helped supervise the job. Kept askin Cap to start the nut at the bottom of the sleeve for me but he just sat there supein'. lol Not flat top...they have bowl. 2900 turbo diesel AC 301.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 5:03pm
Cap'n, this is number 3:
Clap  LOL
LOL
