D17 died
WilliamNEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamNEOH Quote  Post ReplyReply Direct Link To This Post Topic: D17 died
    Posted: 20 Mar 2012 at 6:48am
about 30 minutes use. Was  going uphill, govenor kicked in, turned off the road and depressed clutch to down shift and just died. Back to the house grabbed the 14 and towed her home. An hour later checked fuel line, getting fuel, starting checking for spark and acted like it wanted to start so turned gas on and fired right up. I'm thinking coil, Sound about right. And what is the large nut on the back of the distributor for?
CA,WD-45,D14&D17
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 6:57am
Sounds more like a fuel problem, something floating around in the tank or trash in the carb.  Ever coil I ever had that went bad did so right away.
1944 Allis C
1960 Allis D-17 LP
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 7:19am
If it happens again pull the drain plug from the carb. and see if you have fuel.  If no fuel then it's fuel supply problem or float.  Do it right away not an hour later.  If plenty of fuel flows then look to ignition.
Edited by Stan IL&TN - 20 Mar 2012 at 7:20am
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 8:16pm
My D-14 does that sometimes on a hot day. I think it vapor locks cause I can loosen the fuel cap and the tank breathes. It will start right up after that. On a hot day after a parade I just leave the fuel cap (it is a new one) a little loose.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 8:27pm
fuel cap should have internal vent, Bob
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 8:30pm
Nick did you buy the fuel cap because of this problem or did it start after you got it. It sounds like your tank isn't vented right.
1969 190XT series 3
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 6:43am
i 2nd that motion. sounds like a venting problem.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 6:48am
FUEl.   in 35 years of working on this junk I have found 1 bad coil. They rarely go bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamNEOH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 7:31pm
Had to of been fuel because no issues yesterday and it was ran longer than monday.
CA,WD-45,D14&D17
This page was generated in 0.035 seconds.
