Hey Doc, I forgot....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Hey Doc, I forgot....
    Posted: 13 Mar 2012 at 9:42pm
What is the difference between the gearing on the 175 and 185 final drives?  I put 185 finals on my 175 and was wondering if I will notice a difference?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:05pm
They are supposed to be the same.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:28pm
Hi DrAllis, wasnt there a serial number break where some of the later 185's were geared different than the earlier ones? If so was this done at the ring and pinion or in the final drives?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 6:33am
No........later 180's ( and maybe most 185's) had 1st gear in the transmission slowed down for PTO work, but that was the only gearing change ever.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:10am
the "crop hustler" package, weren't they sped up to pull the same implement but just to go a little faster? or did they just turn up the RPM's on the motor?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:16am
I think it was just a catchy name Matt. Allis did promote speed up throttle back use of their tractors as a way of saving fuel and when you upgraded to higher HP and didn't need to get bigger equipment. Case had a similar promotion.
Wink
I am a Russian Bot
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 10:13am
rpms turned up on the 175/185.
