shopping success
dad2many View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Topic: shopping success
    Posted: 03 Mar 2012 at 6:06pm
Well the trip was a success. Had a CA and loads of equipment follow me home older restoration with low hours but sat under a chicken coop
Sorry about size, uploading from phone.
By the way, current pricing, $2k
think I did well
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:10pm
May need help with what all I got.
Got an ih belly mower adapted to fit, a two row plow, cultivators, a single root rake? Spring ripper? Lift handles. And belly tines?
Edited by dad2many - 03 Mar 2012 at 6:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:20pm
Leaving its home since 1979
wjohn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:26pm
Looks like a good haul. The great big curved thing with a point on the end is a subsoiler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:31pm
What's the little one I've leaned against the sub soiler? It has a little snap hook.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:47pm
I don't see the hand clutch lever. It either didn't come with one or the lever was removed. If it was removed I would guess the hand clutch needs work. Really nice haul you have there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:50pm
Looks like a nice haul. The hand clutch lever on yours seems to be missing. It should be a lever about 30 inches long just inside the right fender. It disconnected the right hand axle shaft to stop the tractor but let the pto continue to run. Many times when these would start to slip they would be bolted together and the lever removed. This eliminated the slip but it also eliminated the hand clutch function also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 7:02pm
There is a little lever laying flat on top but it looks like the hydro lever. There is a little ring lever to the left of that. not sure what it does. I will do more looking tomorrow. Not familiar with these but couldn't pass on the deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 7:07pm
Nick, what year is she. looks like the later style air cleaner with a pin hitch, might be about 1952 and a half, maybe early 53? Looks like somebody did some heavy lifting to load and unload it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 7:22pm
The serial number is CA25065
is this where the hand clutch lever should attach?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 7:24pm
Oh and the loading was easy. The previous owner had a front end loader. Uploading was rough as I have a two hand unloader
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 9:02pm
CA25065 is an early 53. The hand clutch handle comes out of the right front curved section of the platform. This is kinda far away but to the right of DeWayne's right leg, next to the right fender is the handle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 9:06pm
Here you can see the hand clutch handle easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 9:13pm
Yep don't have that lever guess I'll have to find one and figure out if there's an issue. Anybody got one laying around they want to part with?
This page was generated in 0.067 seconds.
