snap coupler disc, what model?
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: snap coupler disc, what model?
    Posted: 25 Feb 2012 at 7:36pm
http://i255.photobucket.com/albums/hh134/ACFarmer/IMAG0233.jpg
http://i255.photobucket.com/albums/hh134/ACFarmer/IMAG0232.jpg
bought this today at a sale, not sure of model. looks like I need a beaming screw.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 7:41pm
Galatians 5:22-24
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 7:53pm
thanks Don, I went back to using Photobucket, and still cant seem to get the pics to come up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 7:58pm
Aaron,
If you have the mouse point over your picture in photobucket, when looking at the album, you have to let it set there, and then the IMG codes will fold out on the bottom. Pick the last line code, and click once (You only need to left click once for it to copy). Then paste that IMG code in your reply text box.
[IMGhttp://img.photobucket.com/albums/v50/Fuldraw/tractors/allis_1.jpg[/IMG]
I took one ] (Bracket) off the code above, so I could post the IMG code only in text mode. Your code should look similar only with the ] After the first [IMG
Edited by Don(MI) - 25 Feb 2012 at 8:00pm
Galatians 5:22-24
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 9:57pm
It has a screw just like on the plows, you have the better one I think it is a 200 series, much better than the more common 20 series. The beaming screw works much better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 7:42am
I have to make a correction here on the disc Don, it is acually a 109 disc that you got, but I did have the other disc model no. right with the lower front adjuster, a number 20.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 10:45am
Looks like a 109.  The 100 series were mounted, either SC or 3 pt., while the 200 series were trailed and could have either a traction booster hitch or regular drawbar hitch.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 1:31pm
As pointed out, it is a model 109. Someone has has replaced the leveling screw assembly with a non-standard setup.
This page was generated in 0.069 seconds.
