Styled WC vs WD fenders
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Styled WC vs WD fenders
    Posted: 06 Feb 2012 at 4:46pm
I say the only difference is the WC fenders have the extra braces on them and that a WD fender would bolt right up to a styled WC.  I think I'm being called out on it on the YT forum.  Can anyone here verify the differeces between styled WC and WD fenders.
AaronSEIA
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 5:00pm
Not interchangable,Look at a WC rearend, then a WD , it will be very obvious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 5:20pm
 Gary, look at the fenders, not the tractor. I just went and looked at my WC parts tractor and my WD45. The shape of the fender looks the same. The shape of the notch looks the same even the 3 triangle bolt pattern looks the same. The difference is in the mounting brackets. I didn't measure them, but would bet, if you interchange the mounting plates, they will bolt up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 5:59pm
 Hey, I been wrong before !  Differant part numbers, and I don't think the attaching holes are located  the same, I always perceived the shape to be differant, too, but I'll stand back for the experts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:17pm
I always figured the basic fender was identical except for the RC-WC braces and a couple of holes drilled where they might not be used on a WD-WD45.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:38pm
  bolt holes are the same  been there done that yrs. ago  ordered 50set with no holes for the IB,S   stillcame thru with the holes   take a wd fender  hold up the wc holes are the same take the 2 braces from a wc fender  an hold it up to them an tack eld theto it an you have a wc fender  sold all them in 6 mo. time when ding vendor work   many were sold for WF&IB,S    MY 2 CENTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:55pm
But, a true RC-WC fender doesn't have the bullet tail light holes, does it??
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:57pm
   OURS DID HAVE AS STATONLY 3 MTG.HOLES
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:16pm
and they will fit the IB (industrial B) as norm said.... with minor modifications.
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:24pm
I have a nice set off a  39 WC, just checked them out in the barn - no hole for bullet light on the left fender-
Have a good one.      BILL P
Edited by BILLP-SE-MI - 06 Feb 2012 at 8:26pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:45pm
We have just gone though this as well. We moved the brackets from the rusted out WC fenders and welded them to some very nice WD fenders. It worked great. The brackets fit like they sould. We have the light holes in the left fender, and it will get a bullet red light. I was told that they did have a light under the seat that was switched. It had the red bullet atop of a work light along with a switch to let you go between the two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 6:38am
I bought a set of WD fenders from Tony C for my IB years back. My body man used the original IB fenders for a pattern to duplicate the holes, and I think he welded in the center, but other than that they looked just like the original IB fenders that we took off when he got done.
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 10:41am
cant remember ever seeing a red bullet attached to the top of the wc under the seat mounted seal beam work light.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 12:25pm
I have WD fenders on my steel rearend WC just using the 3 bolts in the center no plate. They are still very sturdy and work fine.
This page was generated in 0.138 seconds.
