D15 series 2 Hydraulic pump |
whiteheather ![]() Bronze Level ![]() Joined: 29 Jan 2012 Location: B.C. Canada Points: 18 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Feb 2012 at 2:08pm |
I am new to using a tractor, i got a AC D15 series 2 tractor, the hydraulic pump was given to me in a bucket of oil, and a makeshift motor was installed on rear of tractor, (which works fine) however i would like to have the old pump fixed or replaced, if any member has a pic of a D15, and the location to where the pump mounts too, I would be grateful of any help. many thanks in advance. i am a new member to the forum here, and the info is awesome. located in B.C. Canada.......................whiteheather
email whiteheather@citywest.ca |
Travis(NE) ![]() Silver Level ![]() Joined: 24 Sep 2009 Location: Seward NE Points: 300 |
The factory Hyd pump would have been located inside the torque tube. An optional pump could have been in the belt pulley location.
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
it mounts on the front casting infront of grill
can you a pic of the pump????????? will help
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Are you looking for the pump that powers the rear lift or do you have a loader for the tractor that you need a pump for? Loader pump is low pressure/high volumn pump mounted in front of grill, rear lift pump is mounted in the belly of the tractor behind the clutch housing just inside the cover plate with the drain hole.
Yea, I can fix that.....
yes tractor has a loader, the pump is for loader/bucket. ty
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I have this one that is missing the front plate....if you have the plate, measure the distance between the holes. This one might work for you.
ALLIS EXPRESS!
This year: |
Eldon
many thanks, would you have a picture as to where the pump is located, i am at a loss, and new to this. many thanks Charlie
If it is the factory installed high pressure low volume pump used for the rear lift arms it will be mounted in the belly of the tractor ran off of cam lobes on the main shaft in the torque tube. It would be in the same location as the one I circled in this picture of a D17...
![]() If it is a factory auxiliary pump used for a loader or anything else it could be up front driven of the engine front crankshaft pulley or in place of the belt pulley on the right hand side of the torque tube between the engine and operators station. Or could be aftermarket ran off of the PTO out the rear of tractor. Edited by Travis(NE) - 06 Feb 2012 at 4:13pm |
Check to see if it looks like something was bolted to the front of the tractor. Most have a splined shaft that ran under the radiator and slid into a coupling on the crankshaft pulley. They usually had a double row chain coupler from the shaft to the pump....and a sheet metal cover over the pump to protect it.
ALLIS EXPRESS!
This year: |
Oops I missed that part... Sorry Then it may have looked like this... ![]() This is the A-C setup for the 400/500 series loaders on my 19. On a 15 the grill would not need to be cut out. Edited by Travis(NE) - 06 Feb 2012 at 4:46pm |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5901 |
Eldon
Hate to be picky but the way I remember it: the 400 Series loaders ( 445, 414, 415, 417 } had the pump out front like in your picture, and the hydraulic oil was in the loader frame. the 500 Series loaders ( 517, 519 ) the pump was on the R/H side of tractor, and hydraulic oil was in the normal location for 'D' Series. Gary
